Help Center/ Bare Metal Server/ User Guide/ Key Pairs and Passwords/ Obtaining the One-Click Password Reset Plug-In
Updated on 2025-11-21 GMT+08:00
If the password of a BMS failed to be reset, this may be because the one-click password reset plug-in has not been installed on the BMS. Obtain the plug-in and verify its integrity.
Then, you can install the plug-in as instructed in Installing the One-Click Password Reset Plug-in.
Obtain the One-Click Password Reset Plug-In and Verifying Its Integrity (Linux)
  1. Log in to the BMS as user root.
  2. Download the one-click password reset plug-in and SHA256 checksum.
    Obtain the download address from Obtain the One-Click Password Reset Plug-In and SHA256 Checksum based on the region and OS (32- or 64-bit).
    Example commands to download the plug-in and SHA256 checksum for a 32-bit x86 BMS in the CN North-Beijing1 region:
    wget https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
    wget https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
  3. Obtain the hash value of the one-click password reset plug-in.
    sha256sum {Software package directory}/CloudResetPwdAgent.zip
    Replace Software package directory with the directory where the downloaded plug-in is stored.
  4. Check whether the SHA256 hash value obtained in step 2 is consistent with that obtained in step 3.
    • If they are consistent, the verification is successful.
    • If they are inconsistent, repeat steps 2 through 4 to download the correct plug-in and verify it.
Obtain the One-Click Password Reset Plug-In and Verifying Its Integrity (Windows)
  1. Log in to the BMS.
    Obtain the download address from Obtain the One-Click Password Reset Plug-In and SHA256 Checksum based on the region where the BMS resides.
  3. Open Command Prompt as an administrator and run the following command to obtain the hash value of the plug-in:
    certutil –hashfile {Software package directory}\CloudResetPwdAgent.zip SHA256
Table 1 Downloading the one-click password reset plug-in
Region
OS
Name
How to Obtain
CN North-Beijing1
Linux(x86_32)
SHA256 checksum
Linux(x86_64)
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(aarch64)
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-north-1-cloud-reset-pwd.obs.cn-north-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
CN North-Beijing4
Linux(x86_64)
https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-north-4-cloud-reset-pwd.obs.cn-north-4.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
CN East-Shanghai2
Linux(x86_32)
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(x86_64)
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(aarch64)
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-east-2-cloud-reset-pwd.obs.cn-east-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
CN South-Guangzhou
Linux(x86_32)
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(x86_64)
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(aarch64)
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://cn-south-1-cloud-reset-pwd.obs.cn-south-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
CN-Hong Kong
Linux(x86_32)
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(x86_64)
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(aarch64)
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-1-cloud-reset-pwd.obs.ap-southeast-1.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
AP-Bangkok
Linux(x86_32)
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/32/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(x86_64)
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Linux(aarch64)
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/arm/linux/64/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
Windows
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip
SHA256 checksum
https://ap-southeast-2-cloud-reset-pwd.obs.ap-southeast-2.myhuaweicloud.com/windows/reset_pwd_agent/CloudResetPwdAgent.zip.sha256
