Customizing Gateway Inbound Ports
APIG allows you to customize inbound ports for gateways so that clients can access different backend services through different ports.
- Only one protocol can be configured for an added port. Only HTTP and HTTPS are supported.
- For details about the constraints on independent domain names and ports, see Constraints.
- Go to the APIG console.
- In the navigation pane, choose Gateways.
- Click Access Console or the name of the target gateway.
- On the Custom Inbound Port tab page, click Add Inbound Port.
Select a request protocol and enter the inbound port number based on the actual service requirements.
- Click OK.
Related Documents
In the Independent Domain Names area on the Group Information tab, change the port bound to an independent domain name to the new inbound port or select the new inbound port when binding an independent domain name. In this way, you can access different backend services through different ports.
