Configuring Authentication Credentials
For APIs that use app authentication, create credentials to generate credential IDs and key/secret pairs. When calling such an API, bind a credential to the API, use the key/secret pair to replace that in the SDK so that APIG can authenticate your identity.
APIs that use IAM, custom authentication or require no authentication do not need credentials.
You have created an API using app authentication. If no API is created, create one by performing steps provided in Creating an API.
- You can create a maximum of 50 credentials for each gateway. A credential can be bound to a maximum of 1,000 APIs.
- A credential can be bound to multiple APIs that use app authentication, and each such API can be bound with multiple credentials.
Creating a Credential
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > Credentials.
- Click Create Credential and configure parameters based on the following table.
Table 1 Credential information Parameter
Name
Credential name, which can contain 3 to 64 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
Description about the credential. Enter 1 to 255 characters.
Custom Configuration
You can customize the AppKey and AppSecret. However, we recommend using the automatically generated keys and secrets (visible in your credential details) unless you have specific needs.
AppKey
Credential key. It is an identifier and must be globally unique. The value can contain 8 to 200 characters, including letters, digits, underscores (_), and hyphens (-), and must start with a letter or digit.
AppSecret
Credential secret. It is used for identity authentication. The value can contain 8 to 128 characters, including letters, digits, underscores (_), hyphens (-), and special characters: !@#%. The value must start with a letter or digit.
- Click OK.
- After the credential is created, its name and ID are displayed on the Credentials page.
- Click the credential name and view the key and secret.
- Bind or authorize the credential to an API to call the API through app authentication. For details, see Binding/Authorizing Credentials to APIs.
APIG can authenticate the identity and call the associated API based on the key/secret pair of the credential.
Binding a credential to APIs
- On the Credentials page, click the name of the target credential.
- In the APIs area, click Bind to APIs.
- Select an environment, API group, and APIs.
- Click OK.
To unbind an API, click Unbind in the row that contains the API.
Authorizing credentials to an API
- In the navigation pane, choose API Management > API Groups.
- Click a group name to go to the Group Information page.
- On the APIs tab, select the target API and choose More > Authorize Credentials.
- Click Select Credentials.
- Select an environment, search for and select desired credentials, and click OK. The authorized credentials are displayed on the Authorize Credentials page.
To cancel the authorization of a credential, click Cancel Authorization in the Operation column that contains the credential.
Resetting Secret
Reset the secret of a credential as necessary. After resetting, the original secret becomes invalid and APIs to which the credential is bound cannot be called. To call the APIs, update the secret in the SDK. The key is unique and cannot be reset.
- Click the name of the target credential.
- Click Reset Secret.
- Click OK.
Related Documents
- After the API authentication credential is created, you can select the app authentication type based on service requirements to call APIs. For details, see Calling an Open API.
- If you select the simple authentication for App authentication, you need to create an AppCode. For details, see Configuring AppCodes for Simple Authentication.
