Monitoring GPU Metrics
You can use Prometheus and Grafana to observe GPU metrics. This section uses Prometheus as an example to describe how to view the GPU memory usage of a cluster.
The process is as follows:
  1. Accessing Prometheus
    (Optional) Bind a LoadBalancer Service to Prometheus so that Prometheus can be accessed from external networks.
  2. Monitoring GPU Metrics
    After a GPU workload is deployed in the cluster, GPU metrics will be automatically reported.
  3. Accessing Grafana
    View Prometheus monitoring data on Grafana, a visualization panel.
After the Prometheus add-on is installed, you can deploy workloads and Services. The Prometheus server will be deployed as a StatefulSet in the monitoring namespace.
You can create a public network LoadBalancer Service so that Prometheus can be accessed from an external network.
  1. Log in to the CCE console and click the name of the cluster with Prometheus installed to access the cluster console. In the navigation pane, choose Services & Ingresses.
  2. Click Create from YAML in the upper right corner to create a public network LoadBalancer Service.
    apiVersion: v1
    kind: Service
      name: prom-lb     # Service name, which is customizable.
      namespace: monitoring
      labels:
        app: prometheus
        component: server
      annotations:
        kubernetes.io/elb.id: 038ff***     # Replace it with the ID of the public network load balancer in the VPC that the cluster belongs to.
      ports:
        - name: cce-service-0
          protocol: TCP
          port: 88             # Service port, which is customizable.
          targetPort: 9090     # Default Prometheus port. Retain the default value.
      selector:                # The label selector can be adjusted based on the label of a Prometheus server instance.
        app.kubernetes.io/name: prometheus
        prometheus: server
      type: LoadBalancer
  3. After the Service is created, visit Public IP address of the load balancer:Service port to access Prometheus.
  4. Choose Status > Targets to view the targets monitored by Prometheus.
Create a GPU workload. After the workload runs properly, access Prometheus and view GPU metrics on the Graph page.
Table 1 Basic GPU monitoring metrics
Type
Metric
Monitoring Level
Utilization
cce_gpu_utilization
GPU cards
GPU compute usage
cce_gpu_memory_utilization
GPU cards
GPU memory usage
cce_gpu_encoder_utilization
GPU cards
GPU encoding usage
cce_gpu_decoder_utilization
GPU cards
GPU decoding usage
cce_gpu_utilization_process
GPU processes
GPU compute usage of each process
cce_gpu_memory_utilization_process
GPU processes
GPU memory usage of each process
cce_gpu_encoder_utilization_process
GPU processes
GPU encoding usage of each process
cce_gpu_decoder_utilization_process
GPU processes
GPU decoding usage of each process
Memory
cce_gpu_memory_used
GPU cards
Used GPU memory
cce_gpu_memory_total
GPU cards
Total GPU memory
cce_gpu_memory_free
GPU cards
Free GPU memory
cce_gpu_bar1_memory_used
GPU cards
Used GPU BAR1 memory
cce_gpu_bar1_memory_total
GPU cards
Total GPU BAR1 memory
Frequency
cce_gpu_clock
GPU cards
GPU clock frequency
cce_gpu_memory_clock
GPU cards
GPU memory frequency
cce_gpu_graphics_clock
GPU cards
GPU frequency
cce_gpu_video_clock
GPU cards
GPU video processor frequency
Physical status
cce_gpu_temperature
GPU cards
GPU temperature
cce_gpu_power_usage
GPU cards
GPU power
cce_gpu_total_energy_consumption
GPU cards
Total GPU energy consumption
Bandwidth
cce_gpu_pcie_link_bandwidth
GPU cards
GPU PCIe bandwidth
cce_gpu_nvlink_bandwidth
GPU cards
GPU NVLink bandwidth
cce_gpu_pcie_throughput_rx
GPU cards
GPU PCIe RX bandwidth
cce_gpu_pcie_throughput_tx
GPU cards
GPU PCIe TX bandwidth
cce_gpu_nvlink_utilization_counter_rx
GPU cards
GPU NVLink RX bandwidth
cce_gpu_nvlink_utilization_counter_tx
GPU cards
GPU NVLink TX bandwidth
Memory isolation page
cce_gpu_retired_pages_sbe
GPU cards
Number of isolated GPU memory pages with single-bit errors
cce_gpu_retired_pages_dbe
GPU cards
Number of isolated GPU memory pages with dual-bit errors
Accessing Grafana
The Prometheus add-on has had Grafana (an open-source visualization tool) installed and interconnected. You can create a public network LoadBalancer Service so that you can access Grafana from the public network and view Prometheus monitoring data on Grafana.
Click the access address to access Grafana and select a proper dashboard to view the aggregated content.
  2. Click Create from YAML in the upper right corner to create a public network LoadBalancer Service for Grafana.
    apiVersion: v1
    kind: Service
      name: grafana-lb     # Service name, which is customizable
      labels:
        app: grafana
      annotations:
        kubernetes.io/elb.id: 038ff***     # Replace it with the ID of the public network load balancer in the VPC to which the cluster belongs.
      ports:
          protocol: TCP
          port: 80     # Service port, which is customizable
          targetPort: 3000     # Default Grafana port. Retain the default value.
      selector:
        app: grafana
      type: LoadBalancer
  3. After the Service is created, visit Public IP address of the load balancer:Service port to access Grafana and select a proper dashboard to view xGPU resources.
