On this page
Configuring Timeout for a LoadBalancer Ingress
Updated on 2024-12-18 GMT+08:00
LoadBalancer ingresses support the following timeout settings:
  • Idle timeout setting for client connections: Maximum duration for keeping a connection when no client request is received. If no request is received during this period, the load balancer closes the connection and establishes a new one with the client when the next request arrives.
  • Timeout for waiting for a request from a client: If the client fails to send a request header to the load balancer during the timeout duration or the interval for sending body data exceeds a specified period, the load balancer will release the connection.
  • Timeout setting for waiting for a response from a backend server: If the backend server fails to respond during the timeout duration, the load balancer will stop waiting and return HTTP 504 Gateway Timeout to the client.
Notes and Constraints
  • The following table lists the scenarios where timeout can be configured for a Service.
    Timeout Type
    Load Balancer Type
    Supported Cluster Version
    Idle Timeout
    Dedicated
    • v1.19: v1.19.16-r30 or later
    • v1.21: v1.21.10-r10 or later
    • v1.23: v1.23.8-r10 or later
    • v1.25: v1.25.3-r10 or later
    • Other clusters of later versions
    Request Timeout
    Dedicated
    Response Timeout
    Dedicated
  • If you delete the timeout configuration during an ingress update, the timeout configuration on the existing listeners will be retained.
Using kubectl
An ingress configuration example is as follows:
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/elb.port: '80'
    kubernetes.io/elb.id: <your_elb_id>    # In this example, an existing dedicated load balancer is used. Replace its ID with the ID of your dedicated load balancer.
    kubernetes.io/elb.class: performance
    kubernetes.io/elb.keepalive_timeout: '300'  # Timeout setting for client connections
    kubernetes.io/elb.client_timeout: '60'      # Timeout duration for waiting for a request from a client
    kubernetes.io/elb.member_timeout: '60'      # Timeout duration for waiting for a response from a backend server
  rules:
    - host: ''
      http:
        paths:
          - path: /
            backend:
              service:
                port:
                  number: 80
            property:
  ingressClassName: cce
Table 1 Key annotation parameters
Mandatory
Type
No
String
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
The value ranges from 0 to 4000 (in seconds). The default value is 60.
No
String
Timeout for waiting for a request from a client. There are two situations:
  • If the client fails to send a request header to the load balancer during the timeout duration, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer is greater than the timeout duration, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
No
String
Timeout duration for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
