Configuring Nginx Ingresses Using Annotations
Updated on 2024-12-18 GMT+08:00
The nginx-ingress add-on in CCE uses the community chart and image. If the default add-on parameters cannot meet your demands, you can add annotations to define what you need, such as the default backend, timeout, and size of a request body.
This section describes common annotations used for creating an ingress of the Nginx type.
  • The key value of an annotation can only be a string. Other types (such as Boolean values or numeric values) must be enclosed in quotation marks (""), for example, "true", "false", and "100".
  • Nginx ingresses support native annotations of the community. For details, see Annotations.
Ingress Type
Table 1 Ingress type annotations
Type
Supported Cluster Version
kubernetes.io/ingress.class
String
  • nginx: Nginx ingress is used.
  • cce: A proprietary LoadBalancer ingress is used.
This parameter is mandatory when an ingress is created by calling the API.
For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Using kubectl to Create an Nginx Ingress.
Only clusters of v1.21 or earlier
For details about how to use the preceding annotations, see Using kubectl to Create an Nginx Ingress.
Configuring a Redirection Rule
Table 2 Redirection rule annotations
Type
nginx.ingress.kubernetes.io/permanent-redirect
String
Permanently redirects an access request to a target website (status code 301).
nginx.ingress.kubernetes.io/permanent-redirect-code
String
Changes the returned status code of a permanent redirection rule to a specified value.
nginx.ingress.kubernetes.io/temporal-redirect
String
Temporarily redirects an access request to a target website (status code 302).
nginx.ingress.kubernetes.io/ssl-redirect
String
Specifies whether an HTTP request can be redirected to HTTPS only through SSL. The default value is true when the ingress contains an SSL certificate.
nginx.ingress.kubernetes.io/force-ssl-redirect
String
Indicates whether to forcibly redirect a request to HTTPS even if TLS is not enabled for the ingress. When HTTP is used for access, the request is forcibly redirected (status code 308) to HTTPS.
For details, see Configuring Redirection Rules for an Nginx Ingress.
Configuring a URL Rewriting Rule
Table 3 URL rewriting rule annotations
Type
nginx.ingress.kubernetes.io/rewrite-target
String
Target URI where the traffic must be redirected.
For details, see Configuring URL Rewriting Rules for Nginx Ingresses.
Creating a Consistent Hashing Rule for Load Balancing
Table 4 Annotation of consistent hashing for load balancing
Type
nginx.ingress.kubernetes.io/upstream-hash-by
String
Enable consistent hashing for load balancing for backend servers. The parameter value can be an Nginx parameter, a text value, or any combination. For example:
  • nginx.ingress.kubernetes.io/upstream-hash-by: "$request_uri" indicates that requests are hashed based on the request URI.
  • nginx.ingress.kubernetes.io/upstream-hash-by: "$request_uri$host" indicates that requests are hashed based on the request URI and domain name.
  • nginx.ingress.kubernetes.io/upstream-hash-by: "${request_uri}-text-value" indicates that requests are hashed based on the request URI and text value.
For details, see Nginx Ingresses Using Consistent Hashing for Load Balancing.
Customized Timeout Interval
Table 5 Customized timeout interval annotations
Type
nginx.ingress.kubernetes.io/proxy-connect-timeout
String
Customized connection timeout interval. You do not need to set the unit when setting the timeout interval. The default unit is second.
Example:
nginx.ingress.kubernetes.io/proxy-connect-timeout: '120'
Customizing Body Size
Table 6 Annotations of customizing body size
Type
nginx.ingress.kubernetes.io/proxy-body-size
String
When the body size in a request exceeds the upper limit, error 413 is returned to the client. You can use this parameter to adjust the upper limit of the body size.
Example:
nginx.ingress.kubernetes.io/proxy-body-size: 8m
Documentation
For details about annotation parameters supported by Nginx ingresses, see Annotations.
