On this page
Show all
Configuring HTTP/2 for a LoadBalancer Ingress
Updated on 2024-12-18 GMT+08:00
Ingresses can use HTTP/2 to expose Services. Connections from the load balancer to your application use HTTP/1.X by default. If your application is capable of receiving HTTP2 requests, you can add the following field to the ingress annotation to enable the use of HTTP/2:
kubernetes.io/elb.http2-enable: 'true'
  • An HTTPS-compliant load balancer supports HTTP/2.
  • This function is available in clusters of version v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, or v1.28.3-r0.
  • If the advanced configuration for enabling HTTP/2 or the target annotation is deleted, the ELB configuration will not be modified.
The following shows an example YAML file where an existing load balancer is associated:
kind: Ingress
  annotations:
    kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
    kubernetes.io/elb.ip: <your_elb_ip>  # Replace it with the IP of your existing load balancer.
    kubernetes.io/elb.port: '443'
    kubernetes.io/elb.http2-enable: 'true' # Enable HTTP/2.
  tls:
  - secretName: ingress-test-secret
  rules:
  - host: ''
    http:
      paths:
      - path: '/'
        backend:
          service:
            name: <your_service_name>  # Replace it with the name of your target Service.
            port:
              number: 8080             # Replace 8080 with the port number of your target Service.
        property:
  ingressClassName: cce
Table 1 HTTP/2 parameters
Mandatory
Type
No
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid when the listener protocol is HTTP, and defaults to false.
