Configuring SNI for a LoadBalancer Ingress
An SNI certificate is an extended server certificate that allows the same IP address and port number to provide multiple access domain names for external systems. Different security certificates can be used based on the domain names requested by clients to ensure HTTPS communication security.
- This function is supported only in clusters of v1.15.11 and later.
- The SNI option is available only when HTTPS is used.
- Only one domain name can be specified for each SNI certificate. Wildcard-domain certificates are supported.
- Security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters of v1.17.11 or later.
You can enable SNI when the preceding conditions are met. The following uses the automatic creation of a load balancer as an example. In this example, sni-test-secret-1 and sni-test-secret-2 are SNI certificates. The domain names specified by the certificates must be the same as those in the certificates.
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret - hosts: - example.top # Domain name specified when a certificate is issued secretName: sni-test-secret-1 - hosts: - example.com # Domain name specified when a certificate is issued secretName: sni-test-secret-2 rules: - host: example.com http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with the name of your target Service. servicePort: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret - hosts: - example.top # Domain name specified when a certificate is issued secretName: sni-test-secret-1 - hosts: - example.com # Domain name specified when a certificate is issued secretName: sni-test-secret-2 rules: - host: example.com http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 8080 # Replace 8080 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
