Configuring a Node Pool
Updated on 2024-12-18 GMT+08:00
Notes and Constraints
The default node pool DefaultPool does not support the following management operations.
Configuration Management
CCE allows you to highly customize Kubernetes parameter settings on core components in a cluster. For more information, see kubelet.
This function is supported only in clusters of v1.15 and later. It is not displayed for versions earlier than v1.15.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Nodes in the navigation pane and click the Node Pools tab on the right.
  3. Click Manage in the Operation column of the target node pool
  4. On the Manage Components page on the right, change the values of Kubernetes parameters.
    Table 1 kubelet
    Item
    Value
    Modification
    CPU management policy
    cpu-manager-policy
    CPU management policy configuration. For details, see CPU Scheduling.
    • none: disables pods from exclusively occupying CPUs. Select this value if you want a large pool of shareable CPU cores.
    • static: enables pods to exclusively occupy CPUs. Select this value if your workload is sensitive to latency in CPU cache and scheduling.
    • enhanced-static: allows burstable pods to preferentially use CPU cores. Select this value if your workload has huge peak-trough difference and is in the trough state most of the time.
    Default: none
    None
    QPS for requests to kube-apiserver
    kube-api-qps
    Number of queries per second for communication with the API server.
    Default: 100
    None
    Burst for requests to kube-apiserver
    kube-api-burst
    Maximum number of burst requests sent to the API server per second.
    Default: 100
    None
    Limit on the pods managed by kubelet
    max-pods
    Maximum number of pods that can run on a node.
    None
    Limited number of processes in a pod
    pod-pids-limit
    Maximum number of PIDs that can be used in each pod.
    Default: -1, which indicates that the number of PIDs is not limited
    None
    Whether to use a local IP address as a node's ClusterDNS
    with-local-dns
    The default ENI IP address of the node will be automatically added to the node's kubelet configuration as the preferred DNS address.
    Default: false
    None
    QPS limit on creating events
    event-qps
    Number of events that can be generated per second.
    Default: 5
    None
    Allowed unsafe sysctls
    allowed-unsafe-sysctls
    Insecure system configuration allowed.
    Starting from v1.17.17, CCE enables pod security policies for kube-apiserver. Add corresponding configurations to allowedUnsafeSysctls of a pod security policy to make the policy take effect. (This configuration is not required for clusters earlier than v1.17.17.) For details, see Example of Enabling Unsafe Sysctls in Pod Security Policy.
    Default: []
    None
    Node oversubscription
    over-subscription-resource
    Whether to enable node oversubscription.
    If this parameter is set to true, node oversubscription is enabled on nodes.
    • For clusters of versions earlier than v1.23.9-r0 or v1.25.4-r0: enabled (true) by default
    • Disabled by default if the cluster version is v1.23.9-r0, v1.25.4-r0, v1.27-r0, v1.28.1-r0, or later
    None
    Hybrid deployment
    colocation
    Whether to enable hybrid deployment on nodes.
    If this parameter is set to true, hybrid deployment is enabled on nodes.
    None
    Topology management policy
    topology-manager-policy
    Set the topology management policy.
    Valid values are as follows:
    • restricted: kubelet accepts only pods that achieve optimal NUMA alignment on the requested resources.
    • best-effort: kubelet preferentially selects pods that implement NUMA alignment on CPU and device resources.
    • none (default): The topology management policy is disabled.
    • single-numa-node: kubelet allows only pods that are aligned to the same NUMA node in terms of CPU and device resources.
    Default: none
    NOTICE:
    Modifying topology-manager-policy and topology-manager-scope will restart kubelet, and the resource allocation of pods will be recalculated based on the modified policy. In this case, running pods may restart or even fail to receive any resources.
    Topology management scope
    Configure the resource alignment granularity of the topology management policy. Valid values are as follows:
    • container (default)
    • pod
    Default: container
    Specified DNS configuration file
    resolv-conf
    DNS resolution configuration file specified by the container
    Default: null
    None
    Timeout for all runtime requests except long-running requests
    runtime-request-timeout
    Timeout interval of all runtime requests except long-running requests (pull, logs, exec, and attach).
    Default: 2m0s
    This parameter is available only in clusters of v1.21.10-r0, v1.23.8-r0, v1.25.3-r0, or later versions.
    Whether to allow kubelet to pull only one image at a time
    serialize-image-pulls
    Pull an image in serial mode.
    • false: recommended configuration so that an image can be pulled in parallel mode to improve pod startup.
    • true: allows images to be pulled in serial mode.
    • Enabled by default if the cluster version is earlier than v1.21.12-r0, v1.23.11-r0, v1.27.3-r0, v1.28.1-r0 or v1.25.6-r0
    • Disabled by default if the cluster version is v1.21.12-r0, v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.28.1-r0, or later
    Image repository pull limit per second
    registry-pull-qps
    QPS upper limit of an image repository.
    Default: 5
    The value ranges from 1 to 50.
    Upper limit of burst image pull
    registry-burst
    Maximum number of burst image pulls.
    Default: 10
    The value ranges from 1 to 100 and must be greater than or equal to the value of registry-pull-qps.
    Maximum Number of Container Log Files
    container-log-max-files
    Maximum number of container log files. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files.
    Default: 10
    Value range: 2 to 100
    This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
    Maximum Container Log File Size
    container-log-max-size
    Maximum size of a single container log file. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging.
    Default: 50
    Value range: 1 to 4096
    Upper Limit for Image Garbage Collection
    image-gc-high-threshold
    When the kubelet disk usage reaches this value, kubelet starts to collect image garbage.
    Default: 80
    Value range: 1 to 100
    To disable image garbage collection, set this parameter to 100.
    Lower Limit for Image Garbage Collection
    image-gc-low-threshold
    When the disk usage reduces to this value, image garbage collection stops.
    Default: 70
    The value of this parameter cannot be greater than the upper limit for image garbage collection.
    Node memory reservation
    system-reserved-mem
    System memory reservation reserves memory resources for OS system daemons such as sshd and udev.
    Default value: automatically calculated, which varies depending on node flavors. For details, see Node Resource Reservation Policy.
    Optional configurations are as follows:
    • Automatically calculated reserved memory: Use this function for node stability.
      The reserved value varies depending on node flavors. For details, see Node Resource Reservation Policy.
    • Custom reserved memory: The reserved node memory is customized.
    The sum of kube-reserved-mem and system-reserved-mem must be less than 50% of the minimum memory of nodes in the node pool.
    kube-reserved-mem
    Kubernetes memory reservation reserves memory resources for Kubernetes daemons such kubelet and container runtime.
    Hard eviction
    memory.available
    Available memory on a node.
    The value is fixed at 100 MiB.
    For details, see Node-pressure Eviction.
    NOTICE:
    Exercise caution when modifying an eviction configuration item. Improper configuration may cause pods to be frequently evicted or fail to be evicted when the node is overloaded.
    kubelet can identify the following specific file system identifiers:
    • nodefs: main file system of a node. It is used for local disk volumes, emptyDir volumes that are not supported by memory, and log storage. For example, nodefs contains /var/lib/kubelet/.
    • imagefs: file system partition used by a container engine.
    nodefs.available
    Percentage of the available capacity in the filesystem used by kubelet.
    Default: 10%
    Value range: 1% to 99%
    nodefs.inodesFree
    Percentage of available inodes in the filesystem used by kubelet.
    Default: 5%
    imagefs.available
    Percentage of the available capacity in the filesystem used by container runtimes to store resources such as images.
    Default: 10%
    imagefs.inodesFree
    Percentage of available inodes in the filesystem used by container runtimes to store resources such as images.
    This parameter is left blank by default.
    pid.available
    Percentage of allocatable PIDs reserved for pods.
    Default: 10%
    Soft eviction
    memory.available
    The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly.
    Value range: 100 to 1000000
    nodefs.available
    nodefs.inodesFree
    imagefs.available
    imagefs.inodesFree
    pid.available
    Table 2 kube-proxy
    Item
    Value
    Modification
    Maximum number of connection tracking entries
    conntrack-min
    To obtain the value, run the following command:
    sysctl -w net.nf_conntrack_max
    Default: 131072
    None
    Wait time of a closed TCP connection
    conntrack-tcp-timeout-close-wait
    sysctl -w net.netfilter.nf_conntrack_tcp_timeout_close_wait
    Default: 1h0m0s
    None
    Table 3 Docker (available only for node pools that use Docker)
    Item
    Value
    Modification
    Container umask
    native-umask
    The default value normal indicates that the umask value of the started container is 0022.
    Default: normal
    The parameter value cannot be changed.
    Available data space for a single container
    docker-base-size
    Maximum data space that can be used by each container.
    Default: 0
    Insecure image source address
    insecure-registry
    Whether an insecure image source address can be used.
    false
    Maximum size of a container core file
    limitcore
    Maximum size of a core file in a container. The unit is byte.
    If not specified, the value is infinity.
    Default: 5368709120
    None
    Limit on the number of handles in a container
    default-ulimit-nofile
    Maximum number of handles that can be used in a container.
    Default: {soft}:{hard}
    The value cannot exceed the value of the kernel parameter nr_open and cannot be a negative number.
    You can run the following command to obtain the kernel parameter nr_open:
    sysctl -a | grep nr_open
    Image pull timeout
    image-pull-progress-timeout
    If the image fails to be pulled before time outs, the image pull will be canceled.
    Default: 1m0s
    This parameter is supported in v1.25.3-r0 and later.
    Maximum Number of Concurrent Requests for Downloading an Image at a Time
    max-concurrent-downloads
    This parameter specifies the maximum number of concurrent requests for downloading an image at a time.
    Default: 3
    Value range: 1 to 20
    If this parameter is set to a large value, the network performance of other services on the node may be affected or the disk I/O and CPU usage may increase.
    max-size
    Maximum size of a container log file to be dumped. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging.
    Default: 50
    If this parameter is set to a small value, important logs may be lost. If this parameter is set to a large value, too much disk space may be occupied.
    max-file
    Maximum number of log files that can be retained in a container. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files.
    Default: 20
    Table 4 containerd (available only for node pools that use containerd)
    Item
    Value
    Modification
    devmapper-base-size
    Default: 0
    limitcore
    Default: 5368709120
    None
    Default: 1048576
    Image pull timeout
    Default: 1m0s
    Verification on insure skips
    insecure_skip_verify
    Whether to skip repository certificate verification.
    Default: false
    Default: 3
    Maximum Container Log Line Size
    max-container-log-line-size
    Maximum log line size of a container, in the unit of bytes. The log lines exceeding the limit will be split into multiple lines.
    Default: 16384
    Value range: 1 to 2097152
    A larger value will lead to more containerd memory consumption.
  5. Click OK.
