Using GPU Virtualization
This section describes how to use the GPU virtualization capability to isolate the computing power from the GPU memory and efficiently use GPU device resources.
  • A single GPU can be virtualized into a maximum of 20 xGPU devices.
  • After GPU virtualization is used, init containers are not supported.
  • GPU virtualization supports two isolation modes: GPU memory isolation and isolation between GPU memory and computing power. A single GPU can schedule only workloads in the same isolation mode.
  • Autoscaler cannot be used to automatically scale in or out GPU nodes.
  • xGPU isolation does not allow you to request for GPU memory by calling CUDA API cudaMallocManaged(), which is also known as using UVM. For more information, see NVIDIA official documents. Use other methods to request for GPU memory, for example, by calling cudaMalloc().
  • When a containerized application is initializing, the real-time compute monitored by the nvidia-smi may exceed the upper limit of the available compute of the container.
Creating a GPU Virtualization Application
Using the CCE Console
  1. Log in to the CCE console.
  2. Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
  3. Set basic information about the workload.
    Choose Container Settings > Basic Info and configure the GPU quota.
    • Video memory: The unit is MiB. The value must be a positive integer that is a multiple of 128. If the value exceeds the memory of a single GPU, scheduling cannot be performed.
    • Computing power: The unit is %. The value must be a multiple of 5 and cannot exceed 100.
    • If the GPU memory is set to the capacity upper limit of a single GPU or the computing power is set to 100%, the entire GPU will be used.
    • When GPU virtualization is used, the workload scheduler defaults to Volcano and cannot be changed.
    This section describes how to use GPU virtualization. For details about other parameters, see Workloads.
    After completing the setting, click Create.
  4. After a workload is created, you can try to verify the isolation capability of GPU virtualization.
    1. Log in to the container and check the total GPU memory allocated to the pod.
      kubectl exec -it gpu-app -- nvidia-smi
      Expected output:
      Wed Apr 12 07:54:59 2023
      | NVIDIA-SMI 470.141.03   Driver Version: 470.141.03   CUDA Version: 11.4     |
      | GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
      | Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
      |                               |                      |               MIG M. |
      |   0  Tesla V100-SXM2...  Off  | 00000000:21:01.0 Off |                    0 |
      | N/A   27C    P0    37W / 300W |   4912MiB /  5120MiB |      0%      Default |
      |                               |                      |                  N/A |
      | Processes:        |
      |  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
      |        ID   ID                                                   Usage      |
      The expected output indicates that the total GPU memory allocated to the pod is 5120 MiB, and 4912 MiB is used.
    2. Run the following command on the node to check the isolation status of the GPU memory:
      nvidia-smi
      Expected output:
      Wed Apr 12 09:31:10 2023
      |                               |                      |               MIG M. |
      | N/A   27C    P0    37W / 300W |   4957MiB / 16160MiB |      0%      Default |
      |                               |                      |                  N/A |
      | Processes:        |
      |        ID   ID                                                   Usage      |
      |    0   N/A  N/A    760445      C   python                           4835MiB |
      The expected output indicates that the total GPU memory on the node is 16160 MiB, and the example pod uses 4957 MiB.
Using kubectl
  1. Use kubectl to connect to the cluster.
  2. Create an application that uses GPU virtualization.
    The GPU memory isolation and isolation between GPU memory and computing power are supported. The computing power cannot be isolated only. volcano.sh and gpu-core.percentage cannot be set separately.
    Create a gpu-app.yaml file with the following content.
    • Isolate GPU memory only:
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: gpu-app
        replicas: 1
        selector:
          matchLabels:
            app: gpu-app
        template:
            labels:
              app: gpu-app
            containers:
            - name: container-1
              image: <your_image_address>     # Replace it with your image address.
              resources:
                limits:
                  volcano.sh/gpu-mem.128Mi: 40  # GPU memory allocated to the pod. The value is a multiple of 128 MiB (40 x 128 = 5120 MiB).
            imagePullSecrets:
              - name: default-secret
            schedulerName: volcano
    • Isolate the GPU memory from computing power:
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: gpu-app
        replicas: 1
        selector:
          matchLabels:
            app: gpu-app
        template:
            labels:
              app: gpu-app
            containers:
            - name: container-1
              resources:
                limits:
                  volcano.sh/gpu-core.percentage: 25    # Computing power allocated to the pod
            imagePullSecrets:
    Table 1 Key parameters
    Mandatory
    No
    The value is a positive integer that is a multiple of 128 in the unit of MiB. If the value exceeds the memory of a single GPU, scheduling cannot be performed.
    No
    The unit of the computing power is %. The value must be a multiple of 5 and cannot exceed 100.
  3. Run the following command to create an application:
    kubectl apply -f gpu-app.yaml
  4. Verify the isolation capability of GPU virtualization.
      Expected output:
      |                               |                      |               MIG M. |
      |                               |                      |                  N/A |
      | Processes:        |
      |        ID   ID                                                   Usage      |
      nvidia-smi
      Expected output:
      |                               |                      |               MIG M. |
      |                               |                      |                  N/A |
      | Processes:        |
      |        ID   ID                                                   Usage      |
