Help Center/ Cloud Container Engine/ User Guide (Ankara Region)/ Observability/ Best Practices/ Monitoring Metrics of Master Node Components Using Prometheus
This section describes how to use Prometheus to monitor the kube-apiserver, kube-controller, kube-scheduler and etcd-server components on the master node.
Collecting Metrics of Master Node Components Using Prometheus
This section describes how to collect metrics of master node components using Prometheus.
  • The cluster version must be 1.19 or later.
  • You need to install Prometheus using Helm by referring to Prometheus. You need to use prometheus-operator to manage installed Prometheus by referring to Prometheus Operator.
    The Prometheus (Prometheus) add-on is end of maintenance and does not support this function. Therefore, do not use this add-on.
  1. Use kubectl to connect to the cluster.
  2. Modify the ClusterRole of Prometheus.
    kubectl edit ClusterRole prometheus -n {namespace}
    Add the following content under the rules field:
    rules:
    - apiGroups:
      - proxy.exporter.k8s.io
      resources:
      verbs: ["get", "list", "watch"]
  3. Create a file named kube-apiserver.yaml and edit it.
    vi kube-apiserver.yaml
    Example file content:
    apiVersion: monitoring.coreos.com/v1
    kind: ServiceMonitor
      labels:
        app.kubernetes.io/name: apiserver
      namespace: monitoring    # Change it to the namespace where Prometheus will be installed.
      endpoints:
      - bearerTokenFile: /var/run/secrets/kubernetes.io/serviceaccount/token
        interval: 30s
        metricRelabelings:
        - action: keep
          regex: (aggregator_unavailable_apiservice|apiserver_admission_controller_admission_duration_seconds_bucket|apiserver_admission_webhook_admission_duration_seconds_bucket|apiserver_admission_webhook_admission_duration_seconds_count|apiserver_client_certificate_expiration_seconds_bucket|apiserver_client_certificate_expiration_seconds_count|apiserver_current_inflight_requests|apiserver_request_duration_seconds_bucket|apiserver_request_total|go_goroutines|kubernetes_build_info|process_cpu_seconds_total|process_resident_memory_bytes|rest_client_requests_total|workqueue_adds_total|workqueue_depth|workqueue_queue_duration_seconds_bucket|aggregator_unavailable_apiservice_total|rest_client_request_duration_seconds_bucket)
          sourceLabels:
          - __name__
        - action: drop
          regex: apiserver_request_duration_seconds_bucket;(0.15|0.25|0.3|0.35|0.4|0.45|0.6|0.7|0.8|0.9|1.25|1.5|1.75|2.5|3|3.5|4.5|6|7|8|9|15|25|30|50)
          sourceLabels:
          - __name__
          - le
        port: https
        scheme: https
        tlsConfig:
          caFile: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
          serverName: kubernetes
      jobLabel: component
      namespaceSelector:
        matchNames:
        - default
      selector:
        matchLabels:
          component: apiserver
          provider: kubernetes
    Create a ServiceMonitor:
    kubectl apply -f kube-apiserver.yaml
  4. Create a file named kube-controller.yaml and edit it.
    vi kube-controller.yaml
      labels:
        app.kubernetes.io/name: kube-controller
      endpoints:
          interval: 15s
          honorLabels: true
          port: https
          relabelings:
            - regex: (.+)
              replacement: /apis/proxy.exporter.k8s.io/v1beta1/kube-controller-proxy/${1}/metrics
              sourceLabels:
                - __address__
              targetLabel: __metrics_path__
            - regex: (.+)
              replacement: ${1}
              sourceLabels:
                - __address__
              targetLabel: instance
            - replacement: kubernetes.default.svc.cluster.local:443
              targetLabel: __address__
          scheme: https
          tlsConfig:
      jobLabel: app
      namespaceSelector:
        matchNames:
          - kube-system
      selector:
        matchLabels:
          app: kube-controller-proxy
          version: v1
    kubectl apply -f kube-controller.yaml
  5. Create a file named kube-scheduler.yaml and edit it.
    vi kube-scheduler.yaml
      labels:
        app.kubernetes.io/name: kube-scheduler
      endpoints:
          interval: 15s
          honorLabels: true
          port: https
          relabelings:
            - regex: (.+)
              replacement: /apis/proxy.exporter.k8s.io/v1beta1/kube-scheduler-proxy/${1}/metrics
              sourceLabels:
                - __address__
            - regex: (.+)
              replacement: ${1}
              sourceLabels:
                - __address__
          scheme: https
          tlsConfig:
      jobLabel: app
      namespaceSelector:
        matchNames:
          - kube-system
      selector:
        matchLabels:
          app: kube-scheduler-proxy
          version: v1
    kubectl apply -f kube-scheduler.yaml
  6. Create a file named etcd-server.yaml and edit it.
    vi etcd-server.yaml
      labels:
        app.kubernetes.io/name: etcd-server
      endpoints:
          interval: 15s
          honorLabels: true
          port: https
          relabelings:
            - regex: (.+)
              replacement: /apis/proxy.exporter.k8s.io/v1beta1/etcd-server-proxy/${1}/metrics
              sourceLabels:
                - __address__
            - regex: (.+)
              replacement: ${1}
              sourceLabels:
                - __address__
          scheme: https
          tlsConfig:
      jobLabel: app
      namespaceSelector:
        matchNames:
          - kube-system
      selector:
        matchLabels:
          app: etcd-server-proxy
          version: v1
    kubectl apply -f etcd-server.yaml
  7. Access Prometheus and choose Status > Targets.
    The preceding master node components are displayed.
