Overview
Container Storage
CCE container storage is implemented based on Kubernetes container storage APIs (CSI). CCE integrates multiple types of cloud storage and covers different application scenarios. CCE is fully compatible with Kubernetes native storage services, such as emptyDir, hostPath, secret, and ConfigMap.
CCE allows workload pods to use multiple types of storage:
  • In terms of implementation, storage supports Container Storage Interface (CSI) and Kubernetes native storage.
    Type
    CSI
    An out-of-tree volume add-on, which specifies the standard container storage API and allows storage vendors to use standard custom storage plugins that are mounted using PVCs and PVs without the need to add their plugin source code to the Kubernetes repository for unified build, compilation, and release. CSI is a recommended in Kubernetes 1.13 and later versions.
    An "in-tree" volume add-on that is built, compiled, and released with the Kubernetes repository.
  • In terms of storage media, storage can be classified as cloud storage, local storage, and Kubernetes resource objects.
    Type
    Application Scenario
    Cloud storage
    The storage media is provided by storage vendors. Storage volumes of this type are mounted using PVCs and PVs.
    Data requires high availability or needs to be shared, for example, logs and media resources.
    Select a proper cloud storage type based on the application scenario. For details, see Cloud Storage Comparison.
    Local storage
    The storage media is the local data disk or memory of the node. The local persistent volume is a customized storage type provided by CCE and mounted using PVCs and PVs through the CSI. Other storage types are Kubernetes native storage.
    Non-HA data requires high I/O and low latency.
    Select a proper local storage type based on the application scenario. For details, see Local Storage Comparison.
    ConfigMaps and secrets are resources created in clusters. They are special storage types and are provided by tmpfs (RAM-based file system) on the Kubernetes API server.
    ConfigMaps are used to inject configuration data to pods.
    Secrets are used to transmit sensitive information such as passwords to pods.
Item
EVS
OBS
Definition
EVS offers scalable block storage for cloud servers. With high reliability, high performance, and rich specifications, EVS disks can be used for distributed file systems, dev/test environments, data warehouses, and high-performance computing (HPC) applications.
Object Storage Service (OBS) provides massive, secure, and cost-effective data storage for you to store data of any type and size. You can use it in enterprise backup/archiving, video on demand (VoD), video surveillance, and many other scenarios.
Data storage logic
Stores binary data and cannot directly store files. To store files, format the file system first.
Stores objects. Files directly stored automatically generate the system metadata, which can also be customized by users.
Access mode
Accessible only after being mounted to ECSs and initialized.
Accessible through the Internet or Direct Connect (DC). Specify the bucket address and use transmission protocols such as HTTP or HTTPS.
Static storage volumes
Supported. For details, see Using an Existing EVS Disk Through a Static PV.
Supported. For details, see Using an Existing OBS Bucket Through a Static PV.
Dynamic storage volumes
Supported. For details, see Using an EVS Disk Through a Dynamic PV.
Supported. For details, see Using an OBS Bucket Through a Dynamic PV.
Features
Non-shared storage. Each volume can be mounted to only one node.
Shared, user-mode file system
Application scenarios
HPC, enterprise core cluster applications, enterprise application systems, and dev/test
HPC apps here require high-speed and high-IOPS storage, such as industrial design and energy exploration.
Big data analytics, static website hosting, online video on demand (VoD), gene sequencing, intelligent video surveillance, backup and archiving, and enterprise cloud boxes (web disks)
Capacity
TB
EB
Latency
1–2 ms
10 ms
Max. IOPS
2200–256000, depending on flavors
Tens of millions
Bandwidth
MB/s
TB/s
Item
Local PV
Local Ephemeral Volume
emptyDir
hostPath
Definition
Node's local disks form a storage pool (VolumeGroup) through LVM. LVM divides them into logical volumes (LVs) and mounts them to pods.
Kubernetes native emptyDir, where node's local disks form a storage pool (VolumeGroup) through LVM. LVs are created as the storage media of emptyDir and mounted to pods. LVs deliver better performance than the default storage medium of emptyDir.
Kubernetes native emptyDir. Its lifecycle is the same as that of a pod. Memory can be specified as the storage media. When the pod is deleted, the emptyDir volume is deleted and its data is lost.
Used to mount a file directory of the host where a pod is located to a specified mount point of the pod.
Features
Low-latency, high-I/O, and non-HA persistent volume.
Storage volumes are non-shared storage and bound to nodes through labels. Therefore, storage volumes can be mounted only to a single pod.
Local temporary volume. The storage space is from local LVs.
Local temporary volume. The storage space comes from the local kubelet root directory or memory.
Used to mount files or directories of the host file system. Host directories can be automatically created. Pods can be migrated (not bound to nodes).
Storage volume mounting
Static storage volumes are not supported.
Using a Local PV Through a Dynamic PV is supported.
For details, see Using a Local EV.
For details, see Using a Temporary Path.
For details, see hostPath.
High I/O requirements and built-in HA solutions of applications, for example, deploying MySQL in HA mode.
  • Scratch space, such as for a disk-based merge sort
  • Checkpointing a long computation for recovery from crashes
  • Saving the files obtained by the content manager container when web server container data is used
Requiring a node file, for example, if Docker is used, you can use hostPath to mount the /var/lib/docker path of the node.
NOTICE:
Avoid using hostPath volumes as much as possible, as they are prone to security risks. If hostPath volumes must be used, they can only be applied to files or directories and mounted in read-only mode.
