On this page
Configuring Resource Quotas
Namespace-level resource quotas limit the amount of resources available to teams or users when these teams or users use the same cluster. The quotas include the total number of a type of objects and the total amount of compute resources (CPU and memory) consumed by the objects.
Usage
By default, running pods can use the CPUs and memory of a node without restrictions. This means the pods in a namespace may exhaust all resources of the cluster.
Kubernetes provides namespaces for you to group workloads in a cluster. By setting resource quotas for each namespace, you can prevent resource exhaustion and ensure cluster reliability.
You can configure quotas for resources such as CPU, memory, and the number of pods in a namespace. For more information, see Resource Quotas.
The following table recommends how many pods you can configure for your clusters of different sizes.
Cluster Scale
Recommended Number of Pods
50 nodes
2,500 pods
200 nodes
10,000 pods
1000 nodes
30,000 pods
2000 nodes
50,000 pods
In clusters of v1.21 and later, the default resource quotas will be created when a namespace is created if you have enabled enable-resource-quota in Cluster Configuration Management. Table 1 lists the resource quotas based on cluster specifications. You can modify them according to your service requirements.
Table 1 Default resource quotas
Cluster Scale
Pod
Deployment
Secret
ConfigMap
Service
50 nodes
2000
1000
1000
1000
1000
200 nodes
2000
1000
1000
1000
1000
1000 nodes
5000
2000
2000
2000
2000
2000 nodes
5000
2000
2000
2000
2000
Kubernetes provides optimistic concurrency control (OCC), also known as optimistic locking, for frequent data updates. You can use optimistic locking by defining the resourceVersion field. This field is in the object metadata. This field identifies the internal version number of the object. When the object is modified, this field is modified accordingly. You can use kube-apiserver to check whether an object has been modified. When the API server receives an update request containing the resourceVersion field, the server compares the requested data with the resource version number of the server. If they are different, the object on the server has been modified when the update is submitted. In this case, the API server returns a conflict error (409). Obtain the server data, modify the data, and submit the data to the server again. The resource quota limits the total resource consumption of each namespace and records the resource information in the cluster. Therefore, after the enable-resource-quota option is enabled, the probability of resource creation conflicts increases in large-scale concurrency scenarios, affecting the performance of batch resource creation.
  2. In the navigation pane, click Namespaces.
  3. Click Quota Management next to the target namespace.
    This operation cannot be performed on system namespaces kube-system and kube-public.
  4. Set the resource quotas and click OK.
    NOTICE:
    • After setting CPU and memory quotas for a namespace, you must specify the request and limit values of CPU and memory resources when creating a workload. Otherwise, the workload cannot be created. If the quota of a resource is set to 0, the resource usage is not limited.
    • Accumulated quota usage includes the resources used by CCE to create default components, such as the Kubernetes Services (which can be viewed using kubectl) created under the default namespace. Therefore, you are advised to set a resource quota greater than expected to reserve resource for creating default components.
