Permission Dependency of the CCE Console
Some CCE permissions policies depend on the policies of other cloud services. To view or use other cloud resources on the CCE console, enable the access control feature of IAM and assign dependency policies for the other cloud services.
- Dependency policies are assigned based on the CCE FullAccess or CCE ReadOnlyAccess policy you configure.
- Only users and user groups with namespace permissions can gain the view access to resources in clusters.
- If a user is granted the view access to all namespaces of a cluster, the user can view all namespace resources (except secrets) in the cluster. To view secrets in the cluster, the user must gain the admin or edit role in all namespaces of the cluster.
- The view role within a single namespace allows users to view resources only in the specified namespace.
Dependency Policy Configuration
To grant an IAM user the permissions to view or use resources of other cloud services on the CCE console, you must first grant the CCE Administrator, CCE FullAccess, or CCE ReadOnlyAccess policy to the user group to which the user belongs and then grant the dependency policies listed in Table 1 to the user. These dependency policies will allow the IAM user to access resources of other cloud services.
CCE supports fine-grained permissions configuration, but has the following restrictions:
- AOM does not support resource-level monitoring. After operation permissions on specific resources are configured using IAM's fine-grained cluster resource management function, IAM users can view cluster monitoring information on the Dashboard page of the CCE console, but cannot view the data on non-fine-grained metrics.
Console Function |
Dependent Service |
Role or Policy Required |
Cluster overview |
Application Operations Management (AOM) |
Workload management |
Elastic Load Balance (ELB) Application Operations Management (AOM) NAT Gateway Object Storage Service (OBS) |
Except in the following cases, the user does not require any additional role to create workloads.
Cluster management |
Node management |
Elastic Cloud Server (ECS) |
If the permission assigned to an IAM user is CCE Administrator, creating or deleting a node requires the ECS FullAccess or ECS Administrator policy and the VPC Administrator policy. |
Service |
Elastic Load Balance (ELB) NAT Gateway |
Except in the following cases, the user does not require any additional role to create a Service.
Storage |
The CCE Administrator role is required for importing storage devices. |
Namespace management |
Chart management |
Cloud accounts and the IAM users with CCE Administrator assigned can use this function. |
Add-ons |
Cloud accounts and the IAM users with CCE Administrator, CCE FullAccess, or CCE ReadOnlyAccess assigned can use this function. |
Permissions management |
ConfigMaps and Secrets |
Help center |
Switching to other related services |
Software Repository for Container (SWR) |
The CCE console provides links to other related services. To view or use these services, an IAM user must be assigned required permissions for the services. |
