row_number
This function is used to return the row number, starting from 1 and increasing incrementally.
Restrictions
The restrictions on using window functions are as follows:
- Window functions can be used only in select statements.
 - Window functions and aggregate functions cannot be nested in window functions.
 - Window functions cannot be used together with aggregate functions of the same level.
Syntax
row_number() over([partition_clause] [orderby_clause])
Parameters
        Parameter  |
        Mandatory  |
        Description  |
        partition_clause  |
        No  |
        Partition. Rows with the same value in partition columns are considered to be in the same window.  |
        orderby_clause  |
        No  |
        It is used to specify how data is sorted in a window.  |
Return Values
The return value is of the DOUBLE type.
   If the value of a is NULL, NULL is returned.
Example Code
CREATE TABLE logs ( cookieid string, createtime string, pv INT ) ROW FORMAT DELIMITED FIELDS TERMINATED BY ',' stored as textfile;
Adds the following data:
cookie1 2015-04-10 1 cookie1 2015-04-11 5 cookie1 2015-04-12 7 cookie1 2015-04-13 3 cookie1 2015-04-14 2 cookie1 2015-04-15 4 cookie1 2015-04-16 4 cookie2 2015-04-10 2 cookie2 2015-04-11 3 cookie2 2015-04-12 5 cookie2 2015-04-13 6 cookie2 2015-04-14 3 cookie2 2015-04-15 9 cookie2 2015-04-16 7
Example: Groups all records by cookieid, sorts them by pv in descending order, and returns the sequence number of each row in the group. An example command is as follows:
select cookieid, createtime, pv,
       row_number() over (partition by cookieid order by pv desc) as index
from logs;
-- Returned result:
cookie1 2015-04-12 7 1
cookie1 2015-04-11 5 2
cookie1 2015-04-16 4 3
cookie1 2015-04-15 4 4
cookie1 2015-04-13 3 5
cookie1 2015-04-14 2 6
cookie1 2015-04-10 1 7
cookie2 2015-04-15 9 1
cookie2 2015-04-16 7 2
cookie2 2015-04-13 6 3
cookie2 2015-04-12 5 4
cookie2 2015-04-11 3 5
cookie2 2015-04-14 3 6
cookie2 2015-04-10 2 7
