parse_url
This character is used to return the specified part of a given URL. Valid values of partToExtract include HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, and USERINFO.
For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'HOST') returns 'facebook.com'.
When the second parameter is set to QUERY, the third parameter can be used to extract the value of a specific parameter. For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'QUERY', 'k1') returns 'v1'.
Syntax
parse_url(string urlString, string partToExtract [, string keyToExtract])
Parameters
Parameter |
Mandatory |
Type |
Description |
urlString |
Yes |
STRING |
URL. If the URL is invalid, an error is reported. |
partToExtract |
Yes |
STRING |
The value is case-insensitive and can be HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, or USERINFO. |
keyToExtract |
No |
STRING |
If the value of partToExtract is QUERY, the value is obtained based on the key. |
Return Values
The return value is of the STRING type. The return rules are as follows:
- If the value of urlString, partToExtract, or keyToExtract is NULL, NULL is returned.
- If the value of partToExtract does not meet requirements, an error is reported.
Example Code
The value example.com is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'HOST');
The value /over/there/index.dtb is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'PATH');
The value animal is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'QUERY', 'type');
The value nose is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'REF');
The value file is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'PROTOCOL');
The value username@example.com:8042 is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'AUTHORITY');
The value username is returned.
select parse_url('file://username@example.com:666/over/there/index.dtb?type=animal&name=narwhal#nose', 'USERINFO');
