Updated on 2023-10-25 GMT+08:00
day/dayofmonth
This function is used to return the day of a specified date.
Syntax
day(string date), dayofmonth(string date)
Parameters
Table 1 Parameter
Mandatory
Type
date
Yes
DATE
or
STRING
Date that needs to be processed
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
Return Values
The return value is of the INT type.
  • If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
  • If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
  • If the value of date is NULL, NULL is returned.
Example Code
The value 1 is returned.
select day('2023-08-01');
The value NULL is returned.
select day('20230816');
select day(null);
