Disabling or Restoring the Lifecycle of a Table
Function
This section describes how to disable or restore the lifecycle of a specified table or partition.
- If the lifecycle function has been enabled for a table or partitioned table, the system allows you to disable or restore the lifecycle of the table by changing the value of dli.table.lifecycle.status.
- If the lifecycle function is not enabled for a table or partitioned table, the system will add the dli.table.lifecycle.status property to allow you to disable or restore the lifecycle function of the table.
Notes and Constraints
- The table lifecycle function is currently in the open beta test (OBT) phase. If necessary, contact customer service to whitelist it.
- The table lifecycle function currently only supports creating tables and versioning tables using Hive and Datasource syntax.
- The unit of the lifecycle is in days. The value should be a positive integer.
- The lifecycle can be set only at the table level. The lifecycle specified for a partitioned table applies to all partitions of the table.
Syntax
- This syntax can be used to disable or restore the lifecycle of a table at the table level.
1ALTER TABLE table_name SET TBLPROPERTIES("dli.table.lifecycle.status"={enable|disable});
- This syntax can be used to disable or restore the lifecycle of a specified table at the table or partition table level.
1ALTER TABLE table_name [pt_spec] LIFECYCLE {enable|disable};
Keywords
TBLPROPERTIES: Table properties, which can be used to extend the lifecycle of a table.
Parameters
| Parameter | Mandatory | Description |
| table_name | Yes | Name of the table whose lifecycle is to be disabled or restored |
| pt_spec | No | Partition information of the table whose lifecycle is to be disabled or restored. The format is partition_col1=col1_value1, partition_col2=col2_value1.... For a table with multi-level partitions, all partition values must be specified. |
| enable | No | Restores the lifecycle function of a table or a specified partition.
| disable | No | Disables the lifecycle function of a table or a specified partition.
Example
- Example 1: Disable the lifecycle function of the test_lifecycle table.
1alter table test_lifecycle SET TBLPROPERTIES("dli.table.lifecycle.status"='disable');
- Example 2: Disable the lifecycle function for the partition whose time is 20230520 in the test_lifecycle table.
1alter table test_lifecycle partition (dt='20230520') LIFECYCLE 'disable';
- After the lifecycle function of a partitioned table is disabled, the lifecycle function of all partitions within the table will also be disabled.
