Configuring the Recycle Bin for Expired Multi-Versioning Data (Deprecated, Not Recommended)
Function
The multi-versioning feature is to be deprecated and is not recommended. Recommended functions: Hudi multi-versioning cleanup and Hudi archive.
After the multiversion function is enabled, expired backup data will be directly deleted by the system when the insert overwrite or truncate statement is executed. You can configure the trash bin of the OBS parallel file system to accelerate the deletion of expired backup data. To enable the trash bin, add dli.multi.version.trash.dir to the table properties. For details about the syntax for enabling or disabling the multiversion function, see Enabling or Disabling Data Multi-Versioning (Deprecated, Not Recommended).
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
1 2 |
ALTER TABLE [db_name.]table_name SET TBLPROPERTIES ("dli.multi.version.trash.dir"="OBS bucket for expired multiversion backup data"); |
Keywords
- TBLPROPERTIES: This keyword is used to add a key/value property to a table.
Parameters
Parameter |
Description |
db_name |
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_). |
table_name |
Table name |
OBS bucket for expired multiversion backup data |
A directory in the bucket where the current OBS table locates. You can change the directory path as needed. For example, if the current OBS table directory is obs://bucketName/filePath and a Trash directory has been created in the OBS table directory, you can set the trash bin directory to obs://bucketName/filePath/Trash. |
Precautions
- Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
- To automatically empty the trash bin, you need to configure a lifecycle rule for the bucket of the OBS parallel file system. The procedure is as follows:
- On the OBS console, choose Parallel File System in the left navigation pane. Click the name of the target file system. The Overview page is displayed.
- In the left navigation pane, choose Basic Configurations > Lifecycle Rules to create a lifecycle rule.
Figure 1 Creating a lifecycle rule
Example
1 2 |
ALTER TABLE test_table SET TBLPROPERTIES ("dli.multi.version.trash.dir"="/.Trash"); |
