Inserting Data to the RDS Table
Function
This statement is used to insert data in a DLI table to the associated RDS table.
Syntax
- Insert the SELECT query result into a table.
1 2 3 4 5 6 7
INSERT INTO DLI_TABLE SELECT field1,field2... [FROM DLI_TEST] [WHERE where_condition] [LIMIT num] [GROUP BY field] [ORDER BY field] ...;
 - Insert a data record into a table.
1 2
INSERT INTO DLI_TABLE VALUES values_row [, values_row ...];
Keywords
For details about the SELECT keywords, see Basic Statements.
Parameters
        Parameter  |
        Description  |
        DLI_TABLE  |
        Name of the DLI table for which a datasource connection has been created.  |
        DLI_TEST  |
        indicates the table that contains the data to be queried.  |
        field1,field2..., field  |
        Column values in the DLI_TEST table must match the column values and types in the DLI_TABLE table.  |
        where_condition  |
        Query condition.  |
        num  |
        Limit the query result. The num parameter supports only the INT type.  |
        values_row  |
        Value to be inserted to a table. Use commas (,) to separate columns.  |
Precautions
- A DLI table is available.
 - When creating the DLI table, you do not need to specify the Schema information. The Schema information complies with that in the RDS table. If the number and type of fields selected in the SELECT clause do not match the Schema information in the RDS table, the system reports an error.
 - You are advised not to concurrently insert data into a table. If you concurrently insert data into a table, there is a possibility that conflicts occur, leading to failed data insertion.
Example
- Query data in the user table and insert the data into the test table.
1 2 3 4 5 6
INSERT INTO test SELECT ATTR_EXPR FROM user WHERE user_name='cyz' LIMIT 3 GROUP BY user_age
 - Insert data 1 into the test table.
INSERT INTO test VALUES (1);
