SORT BY
Function
This statement is used to achieve the partial sorting of tables according to fields.
Syntax
        1 2 3  |
        SELECT attr_expr_list FROM table_reference SORT BY col_name [ASC | DESC] [,col_name [ASC | DESC],...];  |
Keyword
- ASC/DESC: ASC sorts from the lowest value to the highest value. DESC sorts from the highest value to the lowest value. ASC is the default sort order.
 - SORT BY: Used together with GROUP BY to perform local sorting of a single column or multiple columns for PARTITION.
Precautions
The to-be-sorted table must exist. If this statement is used to sort a table that does not exist, an error is reported.
Example
To sort the student table in ascending order of the score field in Reducer, run the following statement:
        1 2  |
        SELECT * FROM student SORT BY score;  |
