Inserting Data to an HBase Table
Updated on 2024-07-04 GMT+08:00
Function
This statement is used to insert data in a DLI table to the associated HBase table.
Syntax
  • Insert the SELECT query result into a table.
    3
    4
    5
    6
    7
    INSERT INTO DLI_TABLE
      SELECT field1,field2...
      [FROM DLI_TEST]
      [WHERE where_condition]
      [LIMIT num]
      [GROUP BY field]
      [ORDER BY field] ...;
  • Insert a data record into a table.
      VALUES values_row [, values_row ...];
Keywords
For details about the SELECT keywords, see Basic Statements.
Parameters
Table 1 Parameters
DLI_TABLE
Name of the DLI table for which a datasource connection has been created.
DLI_TEST
indicates the table that contains the data to be queried.
field1,field2..., field
Column values in the DLI_TEST table must match the column values and types in the DLI_TABLE table.
where_condition
Query condition.
num
Limit the query result. The num parameter supports only the INT type.
values_row
Value to be inserted to a table. Use commas (,) to separate columns.
Precautions
  • A DLI table is available.
  • In the column family created in Creating a Table and Associating It with HBase, if the column family specified by Cols in OPTIONS does not exist, an error is reported when INSERT INTO is executed.
  • If the row key, column family, or column you need to insert to the HBase table already exists, the existing data in HBase table will be overwritten.
  • You are advised not to concurrently insert data into a table. If you concurrently insert data into a table, there is a possibility that conflicts occur, leading to failed data insertion.
  • INSERT OVERWRITE is not supported.
Example
  • Query data in the user table and insert the data into the test table.
    3
    4
    5
    6
    INSERT INTO test
      SELECT ATTR_EXPR
      FROM user
      WHERE user_name='cyz'
      LIMIT 3
      GROUP BY user_age
  • Insert data 1 into the test table.
    INSERT INTO test
      VALUES (1);
