Viewing Table Statistics
Function
This statement is used to check table statistics. The names and data types of all columns in a specified table will be returned.
Syntax
1 | DESCRIBE [EXTENDED|FORMATTED] [db_name.]table_name; |
Keywords
- EXTENDED: displays all metadata of the specified table. It is used during debugging in general.
- FORMATTED: displays all metadata of the specified table in a form.
Parameters
| Parameter | Description |
| db_name | Database name that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_). |
| table_name | Table name of a database that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. If special characters are required, use single quotation marks ('') to enclose them. |
Precautions
The to-be-queried table must exist. If this statement is used to query the information about a table that does not exist, an error is reported.
Example
To query the names and data types of all columns in the student table, run the following statement:
1 | DESCRIBE student; |
