Deleting a Partition
Updated on 2024-07-04 GMT+08:00
Function
This statement is used to delete one or more partitions from a partitioned table.
Partitioned tables are classified into OBS tables and DLI tables. You can delete one or more partitions from a DLI or OBS partitioned table based on specified conditions. OBS tables also support deleting partitions by specifying filter criteria. For details, see Deleting Partitions by Specifying Filter Criteria (Only Supported on OBS Tables).
Precautions
  • The table in which partitions are to be deleted must exist. Otherwise, an error is reported.
  • The partition to be deleted must exist. Otherwise, an error is reported. To avoid this error, add IF EXISTS to this statement.
Syntax
3
ALTER TABLE [db_name.]table_name
  DROP [IF EXISTS]
  PARTITION partition_spec1[,PARTITION partition_spec2,...];
Keywords
  • DROP: deletes a partition.
  • IF EXISTS: The partition to be deleted must exist. Otherwise, an error is reported.
  • PARTITION: specifies the partition to be deleted
Parameters
Table 1 Parameters
db_name
Database name that contains letters, digits, and underscores (_). It cannot contain only digits and cannot start with an underscore (_).
table_name
Table name of a database that contains letters, digits, and underscores (_). It cannot contain only digits and cannot start with an underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. If special characters are required, use single quotation marks ('') to enclose them.
partition_specs
Partition information, in the format of "key=value", where key indicates the partition field and value indicates the partition value. In a table partitioned using multiple fields, if you specify all the fields of a partition name, only the partition is deleted; if you specify only some fields of a partition name, all matching partitions will be deleted. By default, parameters in partition_specs contain parentheses (), for example, PARTITION (facultyNo=20, classNo=103);.
Example
To help you understand how to use this statement, this section provides an example of deleting a partition from the source data.
  1. Use the DataSource syntax to create an OBS partitioned table.
    An OBS partitioned table named student is created, which contains the student ID (id), student name (name), student faculty number (facultyNo), and student class number (classNo) and uses facultyNo and classNo for partitioning.
    3
    4
    5
    6
    7
    8
    create table if not exists student (
    id int,
    name STRING,
    facultyNo int,
    classNo INT)
    using csv
    options (path 'obs://bucketName/filePath')
    partitioned by (faculytNo, classNo);
  2. Insert partition data into the table.
    You can insert the following data:
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    INSERT into student
    partition (facultyNo = 10, classNo = 101)
    values (1010101, "student01"), (1010102, "student02");
    INSERT into student
    partition (facultyNo = 10, classNo = 102)
    values (1010203, "student03"), (1010204, "student04");
    INSERT into student
    partition (facultyNo = 20, classNo = 101)
    values (2010105, "student05"), (2010106, "student06");
    INSERT into student
    partition (facultyNo = 20, classNo = 102)
    values (2010207, "student07"), (2010208, "student08");
    INSERT into student
    partition (facultyNo = 20, classNo = 103)
    values (2010309, "student09"), (2010310, "student10");
    INSERT into student
    partition (facultyNo = 30, classNo = 101)
    values (3010111, "student11"), (3010112, "student12");
    INSERT into student
    partition (facultyNo = 30, classNo = 102)
    values (3010213, "student13"), (3010214, "student14");
  3. View the partitions.
    You can view all partitions in the table.
    The example code is as follows:
    SHOW partitions student;
    Table 2 Example table data
    facultyNo
    classNo
    facultyNo=10
    classNo=101
    facultyNo=10
    classNo=102
    facultyNo=20
    classNo=101
    facultyNo=20
    classNo=102
    facultyNo=20
    classNo=103
    facultyNo=30
    classNo=101
    facultyNo=30
    classNo=102
  4. Delete a partition.
    • Example 1: deleting a partition by specifying multiple filter criteria
      In this example, the partition whose facultyNo is 20 and classNo is 103 is deleted.
      For details about how to delete a partition by specifying filter criteria, see Deleting Partitions by Specifying Filter Criteria (Only Supported on OBS Tables).
      ALTER TABLE student
      DROP IF EXISTS
      Use the method described in step 3 to check the partitions in the table. You can see that the partition has been deleted.
    • Example 2: deleting a partition by specifying a single filter criterion
      In this example, the partitions whose facultyNo is 30 is deleted. During data insertion, there are two partitions whose facultyNo is 30.
      ALTER TABLE student
      DROP IF EXISTS
      PARTITION (facultyNo = 30);
      Execution result:
      Table 3 Example table data
      facultyNo
      classNo
      facultyNo=10
      classNo=101
      facultyNo=10
      classNo=102
      facultyNo=20
      classNo=101
      facultyNo=20
      classNo=102
      facultyNo=20
      classNo=103
