Help Center/Data Lake Insight/Spark SQL Syntax Reference/Tables/Partition-related Syntax/Renaming a Partition (Only OBS Tables Supported)
Updated on 2024-07-04 GMT+08:00
Function
This statement is used to rename partitions.
Syntax
1 2 3 | ALTER TABLE table_name PARTITION partition_specs RENAME TO PARTITION partition_specs; |
Keywords
- PARTITION: a specified partition
- RENAME: new name of the partition
Parameters
Parameter | Description |
table_name | Table name |
partition_specs | Partition fields |
Precautions
- This statement is used for OBS table operations.
- The table and partition to be renamed must exist. Otherwise, an error occurs. The name of the new partition must be unique. Otherwise, an error occurs.
- If a table is partitioned using multiple fields, you are required to specify all the fields of a partition (at random order) when renaming the partition.
- By default, the partition_specs parameter contains (). For example: PARTITION (dt='2009-09-09',city='xxx')
Example
To modify the name of the city='xxx',dt='2008-08-08' partition in the student table to city='xxx',dt='2009-09-09', run the following statement:
1 2 3 | ALTER TABLE student PARTITION (city='xxx',dt='2008-08-08') RENAME TO PARTITION (city='xxx',dt='2009-09-09'); |
Parent topic:Partition-related Syntax
