What Is CCE?
Cloud Container Engine (CCE) is a Kubernetes cluster hosting service for enterprises. It manages the entire lifecycle of containerized applications and delivers scalable, high-performance solutions for deploying and managing cloud native applications.
Why CCE?
CCE is a one-stop platform integrating compute (ECS), networking (VPC, EIP, and ELB), storage (EVS, SFS, and OBS), and many other services. Multi-AZ, multi-region disaster recovery (DR) ensures high availability (HA) of Kubernetes clusters.
For more information, see Product Advantages and Application Scenarios.
CCE Cluster Types
There are multiple types of CCE clusters.
| Category | Subcategory | CCE Standard |
| Positioning | - | Standard clusters that provide highly reliable and secure containers for commercial use |
| Application scenario | - | For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management on compute, network, and storage resources |
| Specification difference | Network model | Cloud native 1.0 networks: for scenarios where requirements on performance are not high and there are not so many containers
| hostPort | Supported | |
| Network performance | The container network is overlaid with the VPC network, causing certain performance loss. | |
| Network isolation |
| Container resource isolation | cgroups are used to isolate common containers. | |
| Edge infrastructure management | Not supported |
