Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Node/ Node Running/ How Do I Collect Logs of Nodes in a CCE Cluster?
Updated on 2025-07-07 GMT+08:00
Paths of Node Logs
The following tables list log files of CCE nodes.
Table 1 Node logs
Name
Path
kubelet log
  • For clusters of v1.21 or later: /var/log/cce/kubernetes/kubelet.log
  • For clusters of v1.19 or earlier: /var/paas/sys/log/kubernetes/kubelet.log
kube-proxy log
  • For clusters of v1.21 or later: /var/log/cce/kubernetes/kube-proxy.log
  • For clusters of v1.19 or earlier: /var/paas/sys/log/kubernetes/kube-proxy.log
yangtse log (networking)
  • For clusters of v1.21 or later: /var/log/cce/yangtse
  • For clusters of v1.19 or earlier: /var/paas/sys/log/yangtse
canal log
  • For clusters of v1.21 or later: /var/log/cce/canal
  • For clusters of v1.19 or earlier: /var/paas/sys/log/canal
System logs
/var/log/messages
Container engine Logs
  • For Docker nodes: /var/lib/docker
  • For containerd nodes: /var/log/cce/containerd
Table 2 Add-on logs
Name
Path
everest log
  • For v2.1.41 or later:
    • everest-csi-driver: /var/log/cce/kubernetes
    • everest-csi-controller: /var/paas/sys/log/kubernetes
  • For version earlier than v2.1.41:
    • everest-csi-driver: /var/log/cce/everest-csi-driver
    • everest-csi-controller: /var/paas/sys/log/everest-csi-controller
npd log
  • For v1.18.16 or later: /var/paas/sys/log/kubernetes
  • For versions earlier than v1.18.16: /var/paas/sys/log/cceaddon-npd
cce-hpa-controller log
  • For v1.3.12 or later: /var/paas/sys/log/kubernetes
  • For versions earlier than v1.3.12: /var/paas/sys/log/ccehpa-controller
