Kubernetes 1.25 Release Notes
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. This section describes the changes made in Kubernetes 1.25 compared with Kubernetes 1.23.
New Features
Kubernetes 1.25
  • Pod Security Admission is stable. PodSecurityPolicy is deprecated.
    PodSecurityPolicy is replaced by Pod Security Admission. For details about the migration, see Migrate from PodSecurityPolicy to the Built-In PodSecurity Admission Controller.
  • The ephemeral containers are stable.
    An ephemeral container runs temporarily in an existing pod. It is useful for troubleshooting, especially when kubectl exec cannot be used to check a container that breaks down or its image lacks a debugging tool.
  • Support for cgroups v2 enters the stable phase.
    Kubernetes supports cgroups v2. cgroups v2 provides some improvements over cgroup v1. For details, see About cgroup v2.
  • SeccompDefault moves to beta.
    To enable this feature, add the startup parameter --seccomp-default=true to kubelet. In this way, seccomp is set to RuntimeDefault by default, improving system security. Clusters of v1.25 no longer support seccomp.security.alpha.kubernetes.io/pod and container.seccomp.security.alpha.kubernetes.io/annotation. Replace them with the securityContext.seccompProfile field in pods or containers. For details, see Configure a Security Context for a Pod or Container.
    After this feature is enabled, the system calls required by the application may be restricted by the runtime. Ensure that the debugging is performed in the test environment, so that application is not affected.
  • The EndPort in the network policy moves to stable.
    EndPort in Network Policy is stable. This feature is incorporated in version 1.21. EndPort is added to NetworkPolicy. You can specify a port range.
  • Local ephemeral storage capacity isolation is stable.
    This feature provides support for capacity isolation of local ephemeral storage between pods, such as emptyDir. If a pod's consumption of shared resources exceeds the limit, it will be evicted.
  • The CRD verification expression language moves to beta.
    This makes it possible to declare how to validate custom resources using CEL. For details, see Extend the Kubernetes API with CustomResourceDefinitions.
  • KMS v2 APIs are introduced.
    The KMS v2 alpha1 API is introduced to add performance, rotation, and observability improvements. This API uses AES-GCM to replace AES-CBC and uses DEK to encrypt data at rest (Kubernetes Secrets). No additional operation is required during this process. Additionally, data can be read through AES-GCM and AES-CBC. For details, see Using a KMS provider for data encryption.
  • Pod network readiness is introduced.
    Kubernetes 1.25 introduces Alpha support for PodHasNetwork. This status is in the status field of the pod. For details, see Pod network readiness.
  • The two features used for application rollout are stable.
    • In Kubernetes 1.25, minReadySeconds for StatefulSets is stable. It allows each pod to wait for an expected period of time to slow down the rollout of a StatefulSet. For details, see Minimum ready seconds.
    • In Kubernetes 1.25, maxSurge for DaemonSets is stable. It allows a DaemonSet workload to run multiple instances of the same pod on one node during a rollout. This minimizes DaemonSet downtime for users. DaemonSet does not allow maxSurge and hostPort to be used at the same time because two active pods cannot share the same port on the same node. For details, see Perform a Rolling Update on a DaemonSet.
  • Alpha support for running pods with user namespaces is provided.
    This feature maps the root user in a pod to a non-zero ID outside the container. In this way, the container runs as the root user and the node runs as a regular unprivileged user. This feature is still in the internal test phase. The UserNamespacesStatelessPodsSupport gate needs to be enabled, and the container runtime must support this function. For details, see Kubernetes 1.25: alpha support for running Pods with user namespaces.
Kubernetes 1.24
  • Dockershim is removed from kubelet.
    Dockershim was marked deprecated in Kubernetes 1.20 and officially removed from kubelet in Kubernetes 1.24. If you want to use Docker container, switch to cri-dockerd or other runtimes that support CRI, such as containerd and CRI-O.
    Check whether there are agents or applications that depend on Docker Engine. For example, if docker ps, docker run, and docker inspect are used, ensure that multiple runtimes are compatible and switch to the standard CRI.
  • Beta APIs are disabled by default.
    The Kubernetes community found 90% cluster administrators did not care about the beta APIs and left them enabled. However, the beta features are not recommended because these APIs enabled in the production environment by default incur risks. Therefore, in 1.24 and later versions, beta APIs are disabled by default, but the existing beta APIs will retain the original settings.
  • OpenAPI v3 is supported.
    In Kubernetes 1.24 and later versions, OpenAPI V3 is enabled by default.
  • Storage capacity tracking is stable.
    In Kubernetes 1.24 and later versions, the CSIStorageCapacity API supports exposing the available storage capacity. This ensures that pods are scheduled to nodes with enough storage capacity, which reduces pod scheduling delay caused by volume creation and mounting failures. For details, see Storage Capacity.
  • gRPC container probe moves to beta.
    In Kubernetes 1.24 and later versions, the gRPC probe goes to beta. The feature gate GRPCContainerProbe is available by default. For details about how to use this probe, see Configure Probes.
  • LegacyServiceAccountTokenNoAutoGeneration is enabled by default.
    LegacyServiceAccountTokenNoAutoGeneration moves to beta. By default, this feature is enabled, where no secret token is automatically generated for a service account. To use a token that never expires, create a secret to hold the token. For details, see Service account token Secrets.
  • IP address conflict is prevented.
    In Kubernetes 1.24, an IP address pool is soft reserved for the static IP addresses of Services. After you manually enable this function, Service IP addresses will be automatically from the IP address pool to minimize IP address conflict.
  • Clusters are compiled based on Go 1.18.
    Kubernetes clusters of versions later than 1.24 are compiled based on Go 1.18. By default, the SHA-1 hash algorithm, such as SHA1WithRSA and ECDSAWithSHA1, is no longer supported for certificate signature verification. Use the certificate generated by the SHA256 algorithm instead.
  • The maximum number of unavailable StatefulSet replicas is configurable.
    In Kubernetes 1.24 and later versions, the maxUnavailable parameter can be configured for StatefulSets so that pods can be stopped more quickly during a rolling update.
  • Alpha support for non-graceful node shutdown is introduced.
    The non-graceful node shutdown is introduced as alpha in Kubernetes v1.24. A node shutdown is considered graceful only if kubelet's node shutdown manager can detect the upcoming node shutdown action. For details, see Non-graceful node shutdown handling.
Deprecations and Removals
Kubernetes 1.25
  • The iptables chain ownership is cleared up.
    Kubernetes typically creates iptables chains to ensure data packets can be sent to the destination. These iptables chains and their names are for internal use only. These chains were never intended to be part of any Kubernetes API/ABI guarantees. For details, see Kubernetes's IPTables Chains Are Not API.
    In versions later than Kubernetes 1.25, Kubelet uses IPTablesCleanup to migrate the Kubernetes-generated iptables chains used by the components outside of Kubernetes in phases so that iptables chains such as KUBE-MARK-DROP, KUBE-MARK-MASQ, and KUBE-POSTROUTING will not be created in the NAT table. For more details, see Cleaning Up IPTables Chain Ownership.
  • In-tree volume drivers from cloud service vendors are removed.
Kubernetes 1.24
  • In Kubernetes 1.24 and later versions, Service.Spec.LoadBalancerIP is deprecated because it cannot be used for dual-stack protocols. Instead, use custom annotations.
  • In Kubernetes 1.24 and later versions, the --address, --insecure-bind-address, --port, and --insecure-port=0 parameters are removed from kube-apiserver.
  • In Kubernetes 1.24 and later versions, startup parameters --port=0 and --address are removed from kube-controller-manager and kube-scheduler.
  • In Kubernetes 1.24 and later versions, kube-apiserver --audit-log-version and --audit-webhook-version support only audit.k8s.io/v1. In Kubernetes 1.24, audit.k8s.io/v1[alpha|beta]1 is removed, and only audit.k8s.io/v1 can be used.
  • In Kubernetes 1.24 and later versions, the startup parameter --network-plugin is removed from kubelet. This Docker-specific parameter is available only when the container runtime environment is Docker and it is deleted with Dockershim.
  • In Kubernetes 1.24 and later versions, dynamic log clearance has been discarded and removed accordingly. A log filter is introduced to the logs of all Kubernetes system components to prevent sensitive information from being leaked through logs. However, this function may block logs and therefore is discarded. For more details, see Dynamic log sanitization and KEP-1753.
  • VolumeSnapshot v1beta1 CRD is discarded in Kubernetes 1.20 and removed in Kubernetes 1.24. Use VolumeSnapshot v1 instead.
  • In Kubernetes 1.24 and later versions, service annotation tolerate-unready-endpoints discarded in Kubernetes 1.11 is replaced by Service.spec.publishNotReadyAddresses.
  • In Kubernetes 1.24 and later versions, the metadata.clusterName field is discarded and will be deleted in the next version.
  • In Kubernetes 1.24 and later versions, the logic for kube-proxy to listen to NodePorts is removed. If NodePorts conflict with kernel net.ipv4.ip_local_port_range, TCP connections may fail occasionally, which leads to a health check failure or service exception. Before the upgrade, ensure that cluster NodePorts do not conflict with net.ipv4.ip_local_port_range of all nodes in the cluster. For more details, see Kubernetes PR.
Enhanced Kubernetes 1.25 on CCE
During a version maintenance period, CCE periodically updates Kubernetes 1.25 and provides enhanced functions.
For details about cluster version updates, see Release Notes for CCE Cluster Versions.
References
For more details about the performance comparison and function evolution between Kubernetes 1.25 and other versions, see the following documents:
