Configuration Suggestions on CCE Cluster Security
To ensure security, it is recommended that you configure a cluster in the following manner.
Using the CCE Cluster of the Latest Version
Kubernetes releases a major version in about four months. CCE follows the same frequency as Kubernetes to release major versions. To be specific, a new CCE version is released about three months after a new Kubernetes version is released in the community. For example, Kubernetes v1.19 was released in September 2020 and CCE v1.19 was released in March 2021.
The latest cluster version has known vulnerabilities fixed or provides a more comprehensive security protection mechanism. You are advised to select the latest cluster version when creating a cluster. Before a cluster version is deprecated and removed, upgrade your cluster to a supported version.
Disabling the Automatic Token Mounting Function of the Default Service Account
By default, Kubernetes associates the default service account with every pod, which means that the token is mounted to a container. The container can use this token to pass the authentication by the kube-apiserver and kubelet components. In a cluster with RBAC disabled, the service account who owns the token has the control permissions for the entire cluster. In a cluster with RBAC enabled, the permissions of the service account who owns the token depends on the roles associated by the administrator. The service account's token is generally used by workloads that need to access kube-apiserver, such as coredns, autoscaler, and prometheus. For workloads that do not need to access kube-apiserver, you are advised to disable the automatic association between the service account and token.
Two methods are available:
- Method 1: Set the automountServiceAccountToken field of the service account to false. After the configuration is complete, newly created workloads will not be associated with the default service account by default. Configure this field for each namespace as required.
apiVersion: v1 kind: ServiceAccount metadata: name: default automountServiceAccountToken: false ...
When a workload needs to be associated with a service account, explicitly set automountServiceAccountToken to true in the YAML file of the workload.
... spec: template: spec: serviceAccountName: default automountServiceAccountToken: true ...
- Method 2: Explicitly disable the function of automatically associating service accounts with workloads.
... spec: template: spec: automountServiceAccountToken: false ...
Configuring Proper Cluster Access Permissions for Users
CCE allows you to create multiple IAM users. Your account can create different user groups, assign different access permissions to different user groups, and add users to the user groups with corresponding permissions when creating IAM users. In this way, users can control permissions on different regions and assign read-only permissions. Your account can also assign namespace-level permissions for users or user groups. To ensure security, it is advised that minimum user access permissions are assigned.
If you need to create multiple IAM users, configure the permissions of the IAM users and namespaces properly.
Configuring Resource Quotas for Cluster Namespaces
CCE provides resource quota management, which allows users to limit the total amount of resources that can be allocated to each namespace. These resources include CPU, memory, storage volumes, pods, Services, Deployments, and StatefulSets. Proper configuration can prevent excessive resources created in a namespace from affecting the stability of the entire cluster.
Configuring LimitRange for Containers in a Namespace
With resource quotas, cluster administrators can restrict the use and creation of resources by namespace. In a namespace, a pod or container can use the maximum CPU and memory resources defined by the resource quota of the namespace. In this case, a pod or container may monopolize all available resources in the namespace. You are advised to configure LimitRange to restrict resource allocation within the namespace. The LimitRange parameter has the following restrictions:
- Limits the minimum and maximum resource usage of each pod or container in a namespace.
For example, create the maximum and minimum CPU usage limits for a pod in a namespace as follows:
cpu-constraints.yaml
apiVersion: v1 kind: LimitRange metadata: name: cpu-min-max-demo-lr spec: limits: - max: cpu: "800m" min: cpu: "200m" type: Container
Then, run kubectl -n <namespace> create -f cpu-constraints.yaml to complete the creation. If the default CPU usage is not specified for the container, the platform automatically configures the default CPU usage. That is, the default configuration is automatically added after the container is created.
... spec: limits: - default: cpu: 800m defaultRequest: cpu: 800m max: cpu: 800m min: cpu: 200m type: Container
- Limits the maximum and minimum storage space that each PersistentVolumeClaim can apply for in a namespace.
apiVersion: v1 kind: LimitRange metadata: name: storagelimit spec: limits: - type: PersistentVolumeClaim max: storage: 2Gi min: storage: 1Gi
Then, run kubectl -n <namespace> create -f storagelimit.yaml to complete the creation.
Configuring Network Isolation in a Cluster
Enabling the Webhook Authentication Mode with kubelet
CCE clusters of v1.15.6-r1 or earlier are involved, whereas versions later than v1.15.6-r1 are not.
Upgrade the CCE cluster version to 1.13 or 1.15 and enable the RBAC capability for the cluster. If the version is 1.13 or later, no upgrade is required.
When creating a node, you can enable the kubelet authentication mode by injecting the postinstall file (by setting the kubelet startup parameter --authorization-node=Webhook).
- Run the following command to create a ClusterRoleBinding:
kubectl create clusterrolebinding kube-apiserver-kubelet-admin --clusterrole=system:kubelet-api-admin --user=system:kube-apiserver
- For an existing node, log in to the node, change authorization mode in /var/paas/kubernetes/kubelet/kubelet_config.yaml on the node to Webhook, and restart kubelet.
sed -i s/AlwaysAllow/Webhook/g /var/paas/kubernetes/kubelet/kubelet_config.yaml; systemctl restart kubelet
- For a new node, add the following command to the post-installation script to change the kubelet permission mode:
Uninstalling web-terminal After Use
The web-terminal add-on can be used to manage CCE clusters. Keep the login password secure and uninstall the add-on when it is no longer needed.
Using Physical Multi-Tenancy
To ensure that resources of different tenants are isolated and to reduce the attack surface, a separate CCE cluster can be created for each tenant. However, this solution comes with some drawbacks.
- High costs: It may increase the costs as more hardware or VM resources need to be purchased, and more manpower and time need to be spent on managing and maintaining these clusters.
- Low resource utilization: Each tenant requires separate hardware or VM resources to run their clusters, which may result in low resource utilization and wastage.
- Increased management complexity: Managing and maintaining separate clusters for each tenant increases management complexity and may require more manpower and time.
