Monitoring Metrics of Master Node Components Using Prometheus
This section describes how to use Prometheus to monitor the kube-apiserver, kube-controller, kube-scheduler and etcd-server components on the master node.
Collecting Metrics of Master Node Components Using Self-Built Prometheus
This section describes how to collect metrics of master node components using self-built Prometheus.
- The cluster version must be 1.19 or later.
- You need to install self-built Prometheus using Helm by referring to Prometheus. You need to use prometheus-operator to manage installed Prometheus by referring to Prometheus Operator.
The Prometheus (Prometheus) add-on is end of maintenance and does not support this function. Therefore, do not use this add-on.
- Use kubectl to connect to the cluster.
- Modify the ClusterRole of Prometheus.
kubectl edit ClusterRole prometheus -n {namespace}
Add the following content under the rules field:rules: ... - apiGroups: - proxy.exporter.k8s.io resources: - "*" verbs: ["get", "list", "watch"]
- Create a file named kube-apiserver.yaml and edit it.
vi kube-apiserver.yaml
Example file content:apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: labels: app.kubernetes.io/name: apiserver name: kube-apiserver namespace: monitoring # Change it to the namespace where Prometheus will be installed. spec: endpoints: - bearerTokenFile: /var/run/secrets/kubernetes.io/serviceaccount/token interval: 30s metricRelabelings: - action: keep regex: (aggregator_unavailable_apiservice|apiserver_admission_controller_admission_duration_seconds_bucket|apiserver_admission_webhook_admission_duration_seconds_bucket|apiserver_admission_webhook_admission_duration_seconds_count|apiserver_client_certificate_expiration_seconds_bucket|apiserver_client_certificate_expiration_seconds_count|apiserver_current_inflight_requests|apiserver_request_duration_seconds_bucket|apiserver_request_total|go_goroutines|kubernetes_build_info|process_cpu_seconds_total|process_resident_memory_bytes|rest_client_requests_total|workqueue_adds_total|workqueue_depth|workqueue_queue_duration_seconds_bucket|aggregator_unavailable_apiservice_total|rest_client_request_duration_seconds_bucket) sourceLabels: - __name__ - action: drop regex: apiserver_request_duration_seconds_bucket;(0.15|0.25|0.3|0.35|0.4|0.45|0.6|0.7|0.8|0.9|1.25|1.5|1.75|2.5|3|3.5|4.5|6|7|8|9|15|25|30|50) sourceLabels: - __name__ - le port: https scheme: https tlsConfig: caFile: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt serverName: kubernetes jobLabel: component namespaceSelector: matchNames: - default selector: matchLabels: component: apiserver provider: kubernetes
Create a ServiceMonitor:
kubectl apply -f kube-apiserver.yaml
- Create a file named kube-controller.yaml and edit it.
vi kube-controller.yaml
Example file content:apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: labels: app.kubernetes.io/name: kube-controller name: kube-controller-manager namespace: monitoring # Change it to the namespace where Prometheus will be installed. spec: endpoints: - bearerTokenFile: /var/run/secrets/kubernetes.io/serviceaccount/token interval: 15s honorLabels: true port: https relabelings: - regex: (.+) replacement: /apis/proxy.exporter.k8s.io/v1beta1/kube-controller-proxy/${1}/metrics sourceLabels: - __address__ targetLabel: __metrics_path__ - regex: (.+) replacement: ${1} sourceLabels: - __address__ targetLabel: instance - replacement: kubernetes.default.svc.cluster.local:443 targetLabel: __address__ scheme: https tlsConfig: caFile: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt jobLabel: app namespaceSelector: matchNames: - kube-system selector: matchLabels: app: kube-controller-proxy version: v1
kubectl apply -f kube-controller.yaml
- Create a file named kube-scheduler.yaml and edit it.
vi kube-scheduler.yaml
Example file content:apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: labels: app.kubernetes.io/name: kube-scheduler name: kube-scheduler namespace: monitoring # Change it to the namespace where Prometheus will be installed. spec: endpoints: - bearerTokenFile: /var/run/secrets/kubernetes.io/serviceaccount/token interval: 15s honorLabels: true port: https relabelings: - regex: (.+) replacement: /apis/proxy.exporter.k8s.io/v1beta1/kube-scheduler-proxy/${1}/metrics sourceLabels: - __address__ targetLabel: __metrics_path__ - regex: (.+) replacement: ${1} sourceLabels: - __address__ targetLabel: instance - replacement: kubernetes.default.svc.cluster.local:443 targetLabel: __address__ scheme: https tlsConfig: caFile: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt jobLabel: app namespaceSelector: matchNames: - kube-system selector: matchLabels: app: kube-scheduler-proxy version: v1
kubectl apply -f kube-scheduler.yaml
- Create a file named etcd-server.yaml and edit it.
vi etcd-server.yaml
Example file content:apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: labels: app.kubernetes.io/name: etcd-server name: etcd-server namespace: monitoring # Change it to the namespace where Prometheus will be installed. spec: endpoints: - bearerTokenFile: /var/run/secrets/kubernetes.io/serviceaccount/token interval: 15s honorLabels: true port: https relabelings: - regex: (.+) replacement: /apis/proxy.exporter.k8s.io/v1beta1/etcd-server-proxy/${1}/metrics sourceLabels: - __address__ targetLabel: __metrics_path__ - regex: (.+) replacement: ${1} sourceLabels: - __address__ targetLabel: instance - replacement: kubernetes.default.svc.cluster.local:443 targetLabel: __address__ scheme: https tlsConfig: caFile: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt jobLabel: app namespaceSelector: matchNames: - kube-system selector: matchLabels: app: etcd-server-proxy version: v1
kubectl apply -f etcd-server.yaml
- Access Prometheus and choose Status > Targets.
The preceding master node components are displayed.
