Container Engine
Introduction to Container Engines
Container engines, one of the most important components of Kubernetes, manage the lifecycle of images and containers. The kubelet interacts with a container runtime through the Container Runtime Interface (CRI).
CCE supports containerd and Docker. containerd is recommended for its shorter traces, fewer components, higher stability, and less consumption of node resources.
Item |
containerd |
Docker |
Tracing |
kubelet --> CRI plugin (in the containerd process) --> containerd |
Command |
crictl/ctr |
docker |
Kubernetes CRI |
Native support |
Support through dockershim or cri-dockerd |
Pod delayed startup |
Minor |
High |
kubelet CPU/memory usage |
Minor |
High |
Runtime's CPU/memory usage |
Minor |
High |
Common Commands of containerd and Docker
containerd does not support Docker APIs and Docker CLI, but you can run crictl commands to implement similar functions.
Operation |
Docker Command |
containerd Command |
docker |
crictl |
ctr |
List local images. |
docker images |
crictl images |
ctr -n k8s.io i ls |
Pull images. |
docker pull |
crictl pull |
ctr -n k8s.io i pull |
Push images. |
docker push |
None |
ctr -n k8s.io i push |
Delete a local image. |
docker rmi |
crictl rmi |
ctr -n k8s.io i rm |
Check images. |
docker inspect |
crictl inspecti |
None |
Operation |
Docker Command |
docker |
crictl |
ctr |
List containers. |
docker ps |
crictl ps |
ctr -n k8s.io c ls |
Create a container. |
docker create |
crictl create |
ctr -n k8s.io c create |
Start a container. |
docker start |
crictl start |
ctr -n k8s.io run |
Stop a container. |
docker stop |
crictl stop |
None |
Delete a container. |
docker rm |
crictl rm |
ctr -n k8s.io c del |
Connect to a container. |
docker attach |
crictl attach |
None |
Access the container. |
docker exec |
crictl exec |
None |
Query container details. |
docker inspect |
crictl inspect |
ctr -n k8s.io c info |
View container logs. |
docker logs |
crictl logs |
None |
Check the resource usage of the container. |
docker stats |
crictl stats |
None |
Update container resource limits. |
docker update |
crictl update |
None |
Operation |
Docker Command |
docker |
crictl |
ctr |
List pods. |
None |
crictl pods |
None |
View pod details. |
None |
crictl inspectp |
None |
Start a pod. |
None |
crictl start |
None |
Run a pod. |
None |
crictl runp |
None |
Stop a pod. |
None |
crictl stopp |
None |
Delete a pod. |
None |
crictl rmp |
None |
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-cce/public_sys-resources/note_3.0-en-us.png)
Containers created and started by containerd are immediately deleted by kubelet. containerd does not support suspending, resuming, restarting, renaming, and waiting for containers, nor Docker image build, import, export, comparison, push, search, and labeling. containerd does not support file copy. You can log in to the image repository by modifying the configuration file of containerd.
Differences in Tracing
- Docker (Kubernetes 1.23 and earlier):
kubelet --> docker shim (in the kubelet process) --> docker --> containerd
- Docker (community solution for Kubernetes v1.24 or later):
kubelet --> cri-dockerd (kubelet uses CRI to connect to cri-dockerd) --> docker--> containerd
- containerd:
kubelet --> cri plugin (in the containerd process) --> containerd
Although Docker has added functions such as swarm cluster, docker build, and Docker APIs, it also introduces bugs. Compared with containerd, Docker has one more layer of calling. Therefore, containerd is more resource-saving and secure.
