Configuring QoS for a Pod
Updated on 2024-10-14 GMT+08:00
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure QoS rate limiting for inter-pod access to prevent this problem.
Notes and Constraints
The following shows constraints on setting the rate limiting for inter-pod access:
Constraint Type
Tunnel network model
VPC Network Model
Supported versions
All versions
Clusters of v1.19.10 and later
Supported runtime types
Only common containers
Supported pod types
Only non-HostNetwork pods
Supported scenarios
Inter-pod access, pods accessing nodes, and pods accessing services
None
None
Value range of rate limit
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s and 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s.
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
You can add annotations to a workload to specify its egress and ingress bandwidth.
apiVersion: apps/v1
kind: Deployment
  namespace: default
  labels:
    app: test
  replicas: 2
  selector:
    matchLabels:
      app: test
  template:
      labels:
        app: test
      annotations:
        kubernetes.io/ingress-bandwidth: 100M
        kubernetes.io/egress-bandwidth: 100M
      containers:
        - name: container-1
          image: nginx:alpine
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
        - name: default-secret
  • kubernetes.io/ingress-bandwidth: ingress bandwidth of the pod
  • kubernetes.io/egress-bandwidth: egress bandwidth of the pod
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
