Updated on 2025-07-07 GMT+08:00
StorageClass
Introduction
A StorageClass in Kubernetes is a resource that categorizes storage types in a cluster. It can also serve as a configuration template for creating PVs. When creating a PVC or PV, you must specify a StorageClass. This resource object defines the storage mode and configuration parameters for dynamic volume provisioning, such as volume type, access mode, and volume lifecycle policy.
When creating a PVC, you only need to specify the StorageClassName. Kubernetes will then automatically create the PVs and underlying storage based on the StorageClass. This greatly reduces the need for manual creation and maintenance of PVs.
In addition to the default StorageClasses provided by CCE, you can customize StorageClasses. For details, see Application Scenarios of Custom Storage.
Creating a StorageClass Using the CCE Console
The Everest add-on must be in the running state in the target cluster.
  2. Choose Storage in the navigation pane. In the right pane, click the Storage Classes tab. Click Create Storage Class in the upper right corner. In the dialog box displayed, configure parameters.
    StorageClass Type
    Select an underlying storage type.
    Name
    Enter the StorageClass name. The name of a StorageClass must be unique within a cluster.
    Reclaim Policy
    You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
    • Delete: When a PVC is deleted, its associated underlying storage resources will be deleted and the PV resources will be removed. Exercise caution if you select this option.
    • Retain: When a PVC is deleted, both of the PV and its associated underlying storage resources will be retained and the PV is marked as released. If you manually delete the PV afterwards, the underlying storage resources will not be deleted. To bind the PV to a new PVC, you need to remove the original binding information from the PV.
    Binding Mode
    Time when a PV is dynamically created, which can be created immediately or with a delay.
    • Immediate: After a PVC is created, the storage resources and PV will be created and associated with the PVC without delay. Local PVs do not support Immediate.
    • WaitForFirstConsumer: After a PVC is created, it will not be immediately bound to a PV. Instead, the storage resources and PV will be generated and bound to the PVC only after the pod that requires the PVC is scheduled. OBS, SFS, and SFS Turbo do not support WaitForFirstConsumer.
  3. Click Create. On the Storage Classes tab page, view the created StorageClass and its information.
Creating a StorageClass Using a YAML File
As of now, CCE provides StorageClasses such as csi-disk, csi-nas, and csi-obs by default. When defining a PVC, you can use a StorageClassName to automatically create a PV of the corresponding type and automatically create underlying storage resources.
Run the following kubectl command to obtain the StorageClasses that CCE supports. Use the CSI add-on provided by CCE to create a StorageClass.
# kubectl get sc
NAME                PROVISIONER                     AGE
csi-disk            everest-csi-provisioner         17d          # EVS disk
csi-disk-topology   everest-csi-provisioner         17d          # EVS disks created with delay
csi-nas             everest-csi-provisioner         17d          # SFS 1.0
csi-obs             everest-csi-provisioner         17d          # OBS
csi-sfsturbo        everest-csi-provisioner         17d          # SFS Turbo
Each StorageClass contains the default parameters used for dynamically creating a PV. The following is an example of StorageClass for EVS disks:
kind: StorageClass
apiVersion: storage.k8s.io/v1
provisioner: everest-csi-provisioner
parameters:
  csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io
  csi.storage.k8s.io/fstype: ext4
  everest.io/disk-volume-type: SAS
  everest.io/passthrough: 'true'
reclaimPolicy: Delete
allowVolumeExpansion: true
volumeBindingMode: Immediate
Table 1 Key parameters
provisioner
Specifies the storage resource provider, which is the Everest add-on for CCE. Set this parameter to everest-csi-provisioner.
parameters
Specifies the storage parameters, which vary with storage types. For details, see Table 2.
reclaimPolicy
Specifies the value of persistentVolumeReclaimPolicy for creating a PV. The value can be Delete or Retain. If reclaimPolicy is not specified when a StorageClass object is created, the value defaults to Delete.
Specifies whether the PV of this StorageClass supports dynamic capacity expansion. The default value is false. Dynamic capacity expansion is implemented by the underlying storage add-on. This is only a switch.
volumeBindingMode
Specifies the volume binding mode, which is the time when a PV is dynamically created. The value can be Immediate or WaitForFirstConsumer.
mountOptions
This field must be supported by the underlying storage. If this field is not supported but is specified, the PV creation will fail.
Table 2 Parameters
Volume Type
Mandatory
EVS
Yes
Driver type. If an EVS disk is used, the parameter value is fixed at disk.csi.everest.io.
EVS
Yes
If an EVS disk is used, the parameter value can be ext4.
EVS
Yes
EVS disk type. All letters are in uppercase.
  • SAS: high I/O
  • SSD: ultra-high I/O
EVS
Yes
The parameter value is fixed at true, which indicates that the EVS device type is SCSI. No other parameter values are allowed.
SFS Turbo
Yes
Driver type. If SFS Turbo is used, the parameter value is fixed at sfsturbo.csi.everest.io.
SFS Turbo
Yes
If SFS Turbo is used, the value can be nfs.
SFS Turbo
everest.io/share-access-to
Yes
VPC ID of the cluster.
SFS Turbo
everest.io/share-expand-type
No
Extension type. The default value is bandwidth, indicating an enhanced file system. This parameter does not take effect.
SFS Turbo
everest.io/share-source
Yes
The parameter value is fixed at sfs-turbo.
SFS Turbo
everest.io/share-volume-type
No
SFS Turbo StorageClass. The default value is STANDARD, indicating standard and standard enhanced editions. This parameter does not take effect.
SFS Turbo
everest.io/reclaim-policy
No
Whether to retain subdirectories when deleting a PVC. This parameter must be used with reclaim policies. This parameter is available only when the PV reclaim policy is Delete. Options:
  • retain-volume-only: If a PVC is deleted, the PV will be deleted, but its associated subdirectories will be retained.
  • delete: When a PVC is deleted, the associated PV and its subdirectories will also be deleted.
    When a subdirectory is deleted, only the absolute path of the subdirectory configured in the PVC will be deleted. The upper-layer directory will not be deleted.
OBS
Yes
Driver type. If OBS is used, the parameter value is fixed at obs.csi.everest.io.
OBS
Yes
Instance type, which can be obsfs or s3fs.
  • obsfs: a parallel file system
  • s3fs: object bucket
OBS
everest.io/obs-volume-type
Yes
OBS StorageClass.
  • If fsType is set to s3fs, standard buckets (STANDARD) and infrequent access buckets (WARM) are supported.
  • This parameter is invalid when fsType is set to obsfs.
Local PV
Yes
Driver type. If a local PV is used, the parameter value is fixed at local.csi.everest.io.
Local PV
Yes
File system type. The value can only be ext4.
Local PV
volume-type
Yes
Volume type. The value can only be persistent.
When using storage resources in CCE, the most common method is to specify StorageClassName to define the type of storage resources to be created when creating a PVC. The following configuration shows how to use a PVC to apply for a SAS (high I/O) EVS disk (block storage).
apiVersion: v1
kind: PersistentVolumeClaim
  namespace: default
  annotations:
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 10Gi
  storageClassName: csi-disk
To specify the EVS disk type on CCE, use the everest.io/disk-volume-type field. SAS indicates the EVS disk type.
The preceding is a basic method of using StorageClass. In real-world scenarios, you can use StorageClass to perform other operations.
Solution
When annotations is used to specify storage configuration, the configuration is complex. For example, the everest.io/disk-volume-type field is used to specify the EVS disk type.
Define PVC annotations in the parameters field of StorageClass. When compiling a YAML file, you only need to specify StorageClassName.
For example, you can define SAS EVS disk and SSD EVS disk as a StorageClass, respectively. If a StorageClass named csi-disk-sas is defined, it is used to create SAS storage.
Scenario 1: Specifying the Disk Type in a StorageClass
When a user migrates services from an on-premises Kubernetes cluster or other Kubernetes services to CCE, the StorageClass used in the original application YAML file is different from that used in CCE. As a result, a large number of YAML files or Helm chart packages need to be modified when the storage is used, which is complex and error-prone.
Create a StorageClass with the same name as that in the original application YAML file in the CCE cluster. After the migration, you do not need to modify the StorageClassName in the application YAML file.
For example, the StorageClass of the EVS disk used before the migration is disk-standard. After migrating services to a CCE cluster, you can copy the YAML file of the csi-disk StorageClass in the CCE cluster, change its name to disk-standard, and create another StorageClass.
StorageClassName must be specified in the YAML file to use the storage. If not, the storage cannot be created.
If you set the default StorageClass in the cluster, you can create storage without specifying the StorageClassName in the YAML file.
Scenario 2: Specifying the Default StorageClass
When creating storage resources, you must specify an enterprise project. Configuring annotations in each PVC can be a complex process.
Add an enterprise project to a StorageClass. In this case, you do not need to specify an enterprise project when creating a PVC. This is because storage resources will automatically be created in the enterprise project specified in the StorageClass.
Scenario 3: Specifying an Enterprise Project for a StorageClass
This section uses the custom StorageClass of EVS disks as an example to describe how to define SAS EVS disk and SSD EVS disk as a StorageClass, respectively. For example, if you define a StorageClass named csi-disk-sas, which is used to create SAS storage, the differences are shown in the following figure. When editing a PVC's YAML file, you only need to specify StorageClassName.
  • You can customize a high I/O StorageClass in a YAML file. For example, the name csi-disk-sas indicates that the disk type is SAS (high I/O).
    kind: StorageClass
      name: csi-disk-sas                          # Name of the high I/O StorageClass, which can be customized
    parameters:
       everest.io/disk-volume-type: SAS            # High I/O EVS disk type, which cannot be customized.
      everest.io/passthrough: "true"
    allowVolumeExpansion: true                    # true indicates that capacity expansion is allowed.
  • For an ultra-high I/O StorageClass, you can set the class name to csi-disk-ssd to create SSD EVS disk (ultra-high I/O).
    kind: StorageClass
      name: csi-disk-ssd                       # Name of the ultra-high I/O StorageClass, which can be customized
    parameters:
      everest.io/disk-volume-type: SSD         # Ultra-high I/O EVS disk type, which cannot be customized.
reclaimPolicy: indicates the reclaim policies of the underlying cloud storage. The value can be Delete or Retain.
  • Delete: When a PVC is deleted, both the PV and the EVS disk are deleted.
  • Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
If high data security is required, select Retain to prevent data from being deleted by mistake.
After the definition is complete, run the kubectl create commands to create storage resources.
# kubectl create -f sas.yaml
storageclass.storage.k8s.io/csi-disk-sas created
# kubectl create -f ssd.yaml
storageclass.storage.k8s.io/csi-disk-ssd created
Query StorageClass again. The command output is as follows:
# kubectl get sc
csi-disk-sas        everest-csi-provisioner         2m28s
csi-disk-ssd        everest-csi-provisioner         16s
You can specify a StorageClass as the default class. In this way, any PVCs created without specifying StorageClassName will automatically use the default StorageClass.
For example, to specify csi-disk-ssd as the default StorageClass, edit your YAML file as follows:
kind: StorageClass
  annotations:
    storageclass.kubernetes.io/is-default-class: "true"   # Specify the default StorageClass in a cluster. There can only be one default StorageClass per cluster.
parameters:
Run the kubectl create command to create a StorageClass and then check it.
# kubectl get sc
csi-disk-sas             everest-csi-provisioner         114m
csi-disk-ssd (default)   everest-csi-provisioner         9s
When creating EVS or OBS PVCs using a StorageClass in CCE, you can specify an enterprise project to assign the created storage resources (EVS disks and OBS) to. This enterprise project can either be the default one or the same one as the cluster belongs to.
If you do not specify any enterprise project, the enterprise project in StorageClass will be used by default. The storage resources created using the CCE's csi-disk or csi-obs StorageClass belong to the default enterprise project.
If you want the storage resources created using a StorageClass to be in the same enterprise project as the cluster, you can customize a StorageClass and specify the enterprise project ID in it.
To use this function, the Everest add-on must be upgraded to v1.2.33 or later.
kind: StorageClass
  name: csi-disk-epid      # Customize a StorageClass name.
parameters:
  everest.io/enterprise-project-id: 86bfc701-9d9e-4871-a318-6385aa368183  # Specify the enterprise project ID.
