Updated on 2025-12-08 GMT+08:00
Configuring Time Zone Synchronization
When creating a workload, you can enable time zone synchronization, so that the container can use the same time zone as the node.
Enabling Time Zone Synchronization in One Click on the Console
  1. Log in to the CCE console.
  2. Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
  3. In the Basic Info area of the Create Workload page, enable Time Zone Synchronization so that the same time zone will be used for both the container and node.
  4. Complete other settings and click Create Workload.
Manually Mounting a Time Zone Configuration File on the Console
  3. Click Data Storage in the Container Information area under Container Settings and choose Add Volume > hostPath.
    Configure the following parameters:
    • hostPath: /etc/localtime
    • Mount Path: /etc/localtime
    • Permission: Read-only
Manually Mounting a Time Zone Configuration File Using YAML
To use time zone synchronization, you need to mount /etc/localtime on the node to /etc/localtime in the container. In this way, the node and container use the same time zone configuration file.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a file named nginx-deployment.yaml. The name is only an example. You can rename the file as needed.
    vi nginx-deployment.yaml
    Example YAML:
    kind: Deployment
    apiVersion: apps/v1
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: test
      template:
          labels:
            app: test
          volumes:
            - name: date-config  # Custom volume name.
              hostPath:   # Mount the time zone configuration file of the node in hostPath mode.
                path: /etc/localtime  # Path of the time zone configuration file on the node.
          containers:
            - name: container-0
              image: 'nginx:alpine'
              volumeMounts:
                - name: date-config  # Mount the volume to the container. The volume name must be the same as that you defined.
                  readOnly: true # Mount the volume as read-only.
                  mountPath: /etc/localtime # The path in the container where the node's time zone configuration file is mounted.
              imagePullPolicy: IfNotPresent
          imagePullSecrets:
            - name: default-secret
    Press Esc and enter :wq to save the file and exit.
  3. Create the workload.
    kubectl create -f nginx-deployment.yaml
Verifying that the Container and Node Are in the Same Time Zone
  1. Log in to the node and obtain the time zone.
    date -R
    Information similar to the following is displayed:
    Sat, 12 Apr 2025 16:58:47 +0800
  2. Check whether the time zone of the container is the same as that of the node.
    Obtain the pod name.
    kubectl get pod
    Access the container. In the command, <pod_name> specifies the pod name obtained in the previous step.
    kubectl exec -it <pod_name> -- /bin/bash
    Obtain the time zone of the container.
    date -R
    Information similar to the following is displayed, indicating that the time zone of the container is the same as that of the node:
    Sat, 12 Apr 2025 16:59:23 +0800
