Cluster Configuration Management
CCE allows you to manage cluster parameters, through which you can let core components work under your very requirements.
This function is supported only in clusters of v1.15 and later. It is not displayed for versions earlier than v1.15.
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Click next to the target cluster.
- On the Manage Components page on the right, change the values of the Kubernetes parameters listed in the following table.
Table 1 kube-apiserver parameters Parameter
Value
default-not-ready-toleration-seconds
Tolerance time when a node is in the NotReady state.
By default, this tolerance is added to each pod.
Default: 300s
default-unreachable-toleration-seconds
Tolerance time when a node is in the unreachable state.
Default: 300s
max-mutating-requests-inflight
Maximum number of concurrent mutating requests. When the value of this parameter is exceeded, the server rejects requests.
The value 0 indicates no limitation. This parameter is related to the cluster scale. You are advised not to change the value.
Manual configuration is no longer supported since cluster v1.21. The value is automatically specified based on the cluster scale.
- 200 for clusters with 50 or 200 nodes
- 500 for clusters with 1,000 nodes
- 1000 for clusters with 2,000 nodes
max-requests-inflight
Maximum number of concurrent non-mutating requests. When the value of this parameter is exceeded, the server rejects requests.
- 400 for clusters with 50 or 200 nodes
- 1000 for clusters with 1,000 nodes
- 2000 for clusters with 2,000 nodes
service-node-port-range
NodePort port range. After changing the value, go to the security group page and change the TCP/UDP port range of node security groups 30000 to 32767. Otherwise, ports other than the default port cannot be accessed externally.
Default:
30000-32767
Value range:
Min > 20105
Max < 32768
request-timeout
Default request timeout interval of kube-apiserver. Exercise caution when changing the value of this parameter. Ensure that the changed value is proper to prevent frequent API timeout or other errors.
This parameter is supported only by clusters of v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, and later versions.
Default:
1m0s
Value range:
Min ≥ 1s
Max ≤ 1 hour
feature-gates: ServerSideApply
Whether to enable ServerSideApply of kube-apiserver. For details, see Server-Side Apply.
Default:
true
support-overload
Cluster overload control. If enabled, concurrent requests are dynamically controlled based on the resource pressure of master nodes to keep them and the cluster available.
This parameter is supported only by clusters of v1.23 or later.
- false: Overload control is disabled.
- true: Overload control is enabled.
Table 2 kube-scheduler parameters Parameter
Value
kube-api-qps
Query per second (QPS) to use while talking with kube-apiserver.
- If the number of nodes in a cluster is less than 1000, the default value is 100.
- If a cluster contains 1000 or more nodes, the default value is 200.
kube-api-burst
Burst to use while talking with kube-apiserver.
enable-gpu-share
Whether to enable GPU sharing. This parameter is supported only by clusters of v1.23.7-r10, v1.25.3-r0, and later.
- When disabled, ensure that pods in the cluster do not use the shared GPU (that is, the annotation of cce.io/gpu-decision does not exist in pods).
- When enabled, ensure that the annotation of cce.io/gpu-decision exists in pods that use GPU resources in the cluster.
Default: true
Table 3 kube-controller-manager parameters Parameter
Value
concurrent-deployment-syncs
Number of Deployments that are allowed to synchronize concurrently.
Default: 5
concurrent-endpoint-syncs
Number of endpoints that are allowed to synchronize concurrently.
Default: 5
concurrent-gc-syncs
Number of garbage collector workers that are allowed to synchronize concurrently.
Default: 20
concurrent-job-syncs
Number of jobs that can be synchronized at the same time.
Default: 5
concurrent-namespace-syncs
Number of namespaces that are allowed to synchronize concurrently.
Default: 10
concurrent-replicaset-syncs
Number of ReplicaSets that are allowed to synchronize concurrently.
Default: 5
concurrent-resource-quota-syncs
Number of resource quotas that are allowed to synchronize concurrently.
Default: 5
concurrent-service-syncs
Number of Services that are allowed to synchronize concurrently.
Default: 10
concurrent-serviceaccount-token-syncs
Number of service account tokens that are allowed to synchronize concurrently.
Default: 5
concurrent-ttl-after-finished-syncs
Number of TTL-after-finished controller workers that are allowed to synchronize concurrently.
Default: 5
concurrent-rc-syncs
Number of replication controllers that are allowed to synchronize concurrently.
NOTE:This parameter is used only in clusters of v1.21 to v1.23. In clusters of v1.25 and later, this parameter is deprecated (officially deprecated from v1.25.3-r0 on).
Default: 5
horizontal-pod-autoscaler-sync-period
How often HPA audits metrics in a cluster.
Default: 15 seconds
kube-api-qps
kube-api-burst
terminated-pod-gc-threshold
Number of terminated pods that can exist before the terminated pod garbage collector starts deleting terminated pods.
If <= 0, the terminated pod garbage collector is disabled.
Default: 1000
Table 4 Extended controller configuration parameters (supported only by clusters of v1.21 and later) Parameter
Value
enable-resource-quota
Whether to automatically create a resource quota object when creating a namespace.
- false: no auto creation
- true: auto creation enabled For details about the resource quota defaults, see Setting a Resource Quota.
Default: false
- Click OK.
References
