Help Center/
      API Gateway/
        User Guide (Kuala Lumpur Region)/
        FAQs/
        Other FAQs/
      Can I Upload Files Using the POST Method?
        Updated on 2024-08-07 GMT+08:00
Yes.
If you are using dedicated gateways, configure the maximum request body size allowed by setting the request_body_size parameter. The value ranges from 1 MB to 9536 MB.
  Currently, only the request body can be transparently transmitted.
   Parent topic: Other FAQs
