Help Center/
      Cloud Backup and Recovery/
        Best Practices (Kuala Lumpur Region)/
        Using a Custom Script to Implement Application-Consistent Backup/
      Verifying the Application-Consistent Backup Result (Linux)
        Updated on 2022-08-16 GMT+08:00
After application-consistent backup is implemented using customized scripts, perform the following operations to check whether the backup is successful: This section uses the MySQL database as an example.
- Log in to MySQL database and create a database.
- After the database is created, create a stored procedure. For details, see Figure 1.
- Log in to CBR Console and create an application-consistent backup for the desired ECS.
- After the backup is complete, open the /home/rdadmin/Agent/log/rdagent.log file and view the freezing and unfreezing logs to determine the freezing and unfreezing times.
- Use the newly created application-consistent backup to restore the ECS. After the restoration is successful, log in to the ECS and database and check the time when the last data record is inserted.
- Compare the VSS freezing success time recorded in step 5 with the time recorded in step 4. Before the freezing is successful, data insertion is stopped. Therefore, the time in step 5 should be earlier than that in step 4. If the time in step 5 is earlier than that in step 4, the backup is successful.
