Updated on 2022-08-16 GMT+08:00
Context
If other Linux applications need application-consistent backup, you can compile custom scripts to freeze and unfreeze them. To ensure the custom scripts invokable by the Agent, save them in the /home/rdadmin/Agent/bin/thirdparty/ebk_user directory.
The following example uses an application named appexample for demonstration.
appexample is a new database. It provides the appexample -freeze and appexample -unfreeze commands for freezing and unfreezing.
To implement application-consistent backup, you need to compile two scripts named appexample_freeze.sh and appexample_unfreeze.sh. During a backup, the Agent first invokes the appexample_freeze.sh script to freeze I/Os, then activates consistent snapshots on disks to ensure that the backup data is consistent, and finally invokes appexample_unfreeze.sh to unfreeze I/Os.
Figure 1 shows the backup process.
Figure 1 Application-consistent backup flowchart
