Text Generation
In the process of developing AI applications, developers often need to handle tasks related to text understanding and generation. However, traditional text processing methods are typically inefficient and yield suboptimal results. LLMs possess capabilities for text understanding and text-based dialogue. For example, when you input text information, the LLM can understand the content and generate appropriate responses based on that information. Nevertheless, efficiently leveraging these LLMs remains a challenge. This tutorial will guide you on how to use the model service API to call the model for text understanding and content generation. You can also build or extend your own applications or automate tasks using this API, thereby enhancing development efficiency and application quality.
Application Scenarios
You can use the model's text generation capabilities in the following scenarios.
| Scenario | Use Case | Description |
| Content creation | Article generation | Automatically generates practical texts such as articles, news, and comments to improve content production efficiency. |
| Text polishing | Aids authors in creative brainstorming and text refinement for news reports and blog posts. | |
| Intelligent interaction | Intelligent customer service | Generates natural and smooth responses in the customer service system to enhance user experience. |
| Chatbot | In fields such as online consultation and English learning, understand user intent, generate responses according to requirements. | |
| Personalized teaching | Subject question answering | Analyzes the question, explain the key points, outline the solution approach, and present the results. |
| Language learning | As required, engages in conversations in certain languages to help users become accustomed to daily communication in the target language. | |
| Machine translation | Automatic translation | Leverages speech models to achieve simultaneous interpretation, daily subtitle generation, and text language translation. |
| Work processing | Data processing | Processes the data and tasks as required, such as reading research reports, analyzing news, and evaluating content. |
Billing
Inference service deployment is billed based on duration. Costs are incurred when the status is Running or Alarm. Stop the service when not in use. For details, see Inference Deployment Billing Items.
- The model service to be called has been deployed on ModelArts.
- You have obtained the service URL, API key, and model parameter. For details, see Calling a Preset Model.
API Reference
For the complete parameters for model calls, see Model API Call Guide.
Writing Prompts
Prompt is the text input by users when interacting with LLMs to guide the model in generating the desired response. Properly designed and written prompts can enhance the quality and accuracy of the model's output. The core functions of prompts:
- Define the task: Instruct the model on what to do (for example: translation, summarization, creation, inference, etc.).
- Provide context: Add background information to make the response more relevant and tailored to the request.
- Constraint output format: Specify the structure of the response (such as list, JSON, code, etc.).
- Control style and tone: Adjust the professionalism, conciseness, or creativity of the response.
In the Chat API, the messages object is used to pass prompt information to the model. The role field defines the role of the message sender, while the content field carries the message content. The model interprets the content based on the provided role and generates an appropriate response.
- User Message
The end user sends messages to the model, at which point the role field should be set to user. This type of message typically contains specific tasks or information that the user wants the model to process.
The following is a simple user message requesting the model to introduce itself.
"messages": [ { "role": "user", "content": "Introduce yourself. "} ] - System Message
Used to set the model's long-term personality, behavioral guidelines, and conversation context. In this case, the role field should be set to system. If you configure system messages, place them in the first position of the messages list.
The following is an example of a system message that indicates the model is an assistant and restricts the content of its responses.
"messages": [ {"role": "system", "content": " You are a helpful and concise assistant. Keep your responses to no more than two sentences." } ] - Model Message
Used to provide conversation history, in which case the role field should be set to assistant. In multi-turn conversations, you need to pass in the conversation history, so that the model can remember what it said before and maintain coherence.
"messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"}, {"role": "assistant", "content": "Hello! Nice to meet you! I am your AI assistant and I'm here to help you with anything you need. Whether it's answering questions, assisting with analysis, or just having a chat, I'm ready to assist. Is there anything specific you need help with?"}, {"role": "user","content": "Introduce yourself" } ]
Single-Turn Dialogue
Interact with the model in a single turn of dialogue, where the model returns content based on system and user messages.
Since it is non-streaming output, the model needs to process all content before returning it to you in one go, which may introduce some latency.
The following is an example code for a single-turn conversation. You can replace the model by modifying the model parameter. For details about the model parameter, see Creating a Chat Request.
curl -X POST "https://***/v2/infer/***/v1/chat/completions" \
-H "Content-Type: application/json" \
-H "Authorization: Bearer $API_KEY" \
-d '{
"model": "qwen3_32b",
"messages": [
}' import requests
import json
if __name__ == '__main__':
url = "https://***/v2/infer/***/v1/chat/completions" # API address
api_key = "API_KEY" # Replace API_KEY with the obtained API key.
# Send request.
headers = {
'Content-Type': 'application/json',
'Authorization': f'Bearer {api_key}'
data = {
"model": "qwen3_32b", # Model
"messages": [
"role": "system",
"role": "user",
"content": "Hello"
response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
# Print result.
print(response.status_code)
print(response.text) Multi-Turn Dialogue
Combining system messages, model messages, and user messages enables multi-turn conversations, allowing for multiple dialogues on a single topic.
Note: chat.completions API is stateless. In each request, all historical information is included in the messages field and the role field is set to inform the model of previous conversations from different roles, ensuring contextually relevant and continuous dialogue.
The following is an example code for a multi-turn conversation. You can replace the model by modifying the model parameter. For details about the model parameter, see Creating a Chat Request.
-d '{
"messages": [
{"role": "assistant", "content": "Hello! Nice to meet you!"},
{"role": "user", "content": "Introduce yourself."}
}' import requests
import json
# Send request.
headers = {
data = {
"messages": [
# Print result.
print(response.text) Streaming Output
With the LLM output, dynamic content is displayed as it is generated. This allows users to see intermediate outputs without waiting for the entire inference process to complete, improving the user experience by reducing perceived wait times (viewing content as it is produced).
The following is an example of stream output code. You can replace the model by modifying the model parameter. For details about the model parameter, see Creating a Chat Request.
-d '{
"messages": [
"stream": true
}' import requests
import json
# Send request.
headers = {
data = {
"messages": [
{"role": "system", "content": "You are a helpful assistant." },
{"role": "user","content": "Hello" }
"stream": True
# Print result.
print(response.text) Function Call
Function calling enables models to dynamically call external APIs by defining tool interface specifications, facilitating seamless function expansion.
The following is an example code using function calling. You can replace the model by modifying the model parameter. For details about the model parameter, see Creating a Chat Request.
Python SDK example:
import requests
import json
def get_weather(location: str, unit: str):
return f"Getting the weather for {location} in {unit}..."
# Send request.
headers = {
data = {
"messages": [
{"role": "user", "content": "Beijing weather"}
"tools": [
"type": "function",
"function": {
"name": "get_weather",
"description": "Get weather information for a specified location",
"parameters": {
"type": "object",
"properties": {
"location": {
"type": "string",
"description": "City and state, e.g., 'San Francisco, CA'"
"required": [
"location"
"thinking": {
"type": "enabled" # Specifies whether to enable deep thinking. It is disabled by default.
# Print result.
print(response.text) Setting the Model Response Length Limit
To control costs or adjust response length, for example, limiting a response to 500 characters, you can configure the max_tokens field in your request to set a maximum output length.
The following is an example code for setting the model response length limit. You can replace the model parameter with your desired model. For details about the model parameter, see Creating a Chat Request.
-d '{
"messages": [
"max_tokens": 1024
}' import requests
import json
# Send request.
headers = {
data = {
"messages": [
"max_tokens": 1024
# Print result.
print(response.text) What is your overall rating for this page?
