Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ FAQs/ Networking/ Network Fault/ How Do I Locate a Workload Networking Fault?
Troubleshooting Process
The issues here are described in order of how likely they are to occur.
Check these causes one by one until you find the cause of the fault.
Check Item 1: Container and Container Port
Log in to the CCE console or use kubectl to query the IP address of the pod. Then, log in to the node or container in the cluster and run the curl command to manually call the API. Check whether the expected result is returned.
If <container IP address>:<port> cannot be accessed, you are advised to log in to the application container and access <127.0.0.1>:<port> to locate the fault.
Common issues:
  1. The container port is incorrectly configured (the container does not listen to the access port).
  2. The URL does not exist (no related path exists in the container).
  3. A Service exception (a Service bug in the container) occurs.
  4. Check whether the cluster network kernel component is abnormal (container tunnel network model: openswitch kernel component; VPC network model: ipvlan kernel component).
Check Item 2: Node IP Address and Node Port
Only NodePort or LoadBalancer Services can be accessed using the node IP address and node port.
  • NodePort Services:
    The access port of a node is the port exposed externally by the node.
  • LoadBalancer Service:
    You can view the node port of a LoadBalancer Service by editing the YAML file.
Example:
nodePort: 30637 indicates the exposed node port. targetPort: 80 indicates the exposed pod port. port: 123 is the exposed Service port. LoadBalancer Services also use this port to configure the ELB listener.
After finding the node port (nodePort), access <IP address>:<port> of the node where the container is located and check whether the expected result is returned.
Common issues:
  1. The service port is not allowed in the inbound rules of the node.
  2. A custom route is incorrectly configured for the node.
  3. The label of the pod does not match that of the Service (created using kubectl or API).
Check Item 3: ELB IP Address and Port
There are several possible causes if <IP address>:<port> of the ELB cannot be accessed, but <IP address>:<port> of the node can be accessed.
Possible causes:
  • The backend server group of the port or URL does not meet the expectation.
  • The security group on the node has not exposed the related protocol or port to the ELB.
  • The health check of the layer-4 load balancing is disabled. Enable it if necessary.
  • The certificate used for Services of layer-7 load balancing has expired.
Common issues:
  1. When exposing a layer-4 ELB load balancer, if you have not enabled health check on the console, the load balancer may route requests to abnormal nodes.
  2. For UDP access, the ICMP port of the node has not been allowed in the inbound rules.
Check Item 4: NAT Gateway + Port
Generally, no EIP is configured for the backend server of NAT. Otherwise, exceptions such as network packet loss may occur.
Check Item 5: Whether the Security Group of the Node Where the Container Is Located Allows Access
Log in to the management console, choose Service List > Networking > Virtual Private Cloud. On the Network console, choose Access Control > Security Groups, locate the security group rule of the CCE cluster, and modify and harden the security group rule.
  • CCE cluster:
    The security group name of the node is {Cluster name}-cce-node-{Random characters}.
Check the following:
  • IP address, port, and protocol of an external request to access the workloads in the cluster. They must be allowed in the inbound rule of the cluster security group.
  • IP address, port, and protocol of a request by a workload to visit external applications outside the cluster. They must be allowed in the outbound rule of the cluster security group.
For details about security group configuration, see How Can I Configure a Security Group Rule in a Cluster?.
