Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ FAQs/ Cluster/ Cluster Creation/ Is Management Scale of a Cluster Related to the Number of Master Nodes?
Management scale indicates the maximum number of nodes that can be managed by a cluster. If you select 50 nodes, the cluster can manage a maximum of 50 nodes.
The number of master nodes varies according to the cluster specification, but is not affected by the management scale.
After the multi-master node mode is enabled, three master nodes will be created. If one of them is faulty, the cluster can still run properly. The services will not be affected.
