Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Best Practices/ Storage/ Changing the Storage Class Used by a Cluster of v1.15 from FlexVolume to CSI Everest
In clusters later than v1.15.11-r1, CSI (the everest add-on) has taken over all functions of fuxi FlexVolume (the storage-driver add-on) for managing container storage. You are advised to use CSI Everest.
To migrate your storage volumes, create a static PV to associate with the original underlying storage, and then create a PVC to associate with this static PV. When you upgrade your application, mount the new PVC to the original mounting path to migrate the storage volumes.
Services will be interrupted during the migration. Therefore, properly plan the migration and back up data.
  1. (Optional) Back up data to prevent data loss in case of exceptions.
  2. Configure a YAML file of the PV in the CSI format according to the PV in the FlexVolume format and associate the PV with the existing storage.
    To be specific, run the following commands to configure the pv-example.yaml file, which is used to create a PV.
    touch pv-example.yaml
    vi pv-example.yaml
    Configuration example of a PV for an EVS volume:
    apiVersion: v1
    kind: PersistentVolume
      labels:
        failure-domain.beta.kubernetes.io/region: eu-west-0
        failure-domain.beta.kubernetes.io/zone: <zone name>
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
      accessModes:
      - ReadWriteOnce
      capacity:
        storage: 10Gi
      csi:
        driver: disk.csi.everest.io
        fsType: ext4
        volumeAttributes:
          everest.io/disk-mode: SCSI
          everest.io/disk-volume-type: SAS
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
        volumeHandle: 0992dbda-6340-470e-a74e-4f0db288ed82
      persistentVolumeReclaimPolicy: Delete
      storageClassName: csi-disk
    Pay attention to the fields in bold and red. The parameters are described as follows:
    Table 1 EVS volume configuration parameters
    Region where the EVS disk is located. Use the same value as that of the FlexVolume PV.
    AZ where the EVS disk is located. Use the same value as that of the FlexVolume PV.
    name
    Name of the PV, which must be unique in the cluster.
    storage
    EVS volume capacity in the unit of Gi. Use the value of spec.capacity.storage of the FlexVolume PV.
    driver
    Storage driver used to attach the volume. Set the driver to disk.csi.everest.io for the EVS volume.
    volumeHandle
    Volume ID of the EVS disk. Use the value of spec.flexVolume.options.volumeID of the FlexVolume PV.
    EVS disk mode. Use the value of spec.flexVolume.options.disk-mode of the FlexVolume PV.
    EVS disk type. Use the value of kubernetes.io/volumetype in the storage class corresponding to spec.storageClassName of the FlexVolume PV.
    storageClassName
    Name of the Kubernetes storage class associated with the storage volume. Set this field to csi-disk for EVS disks.
    Configuration example of a PV for an SFS volume:
    apiVersion: v1
      annotations:
      accessModes:
      - ReadWriteMany
      capacity:
        storage: 10Gi
      csi:
        driver: nas.csi.everest.io
        fsType: nfs
        volumeAttributes:
          everest.io/share-export-location:  # Shared path of the file storage
        volumeHandle: 682f00bb-ace0-41d8-9b3e-913c9aa6b695
      storageClassName: csi-nas
    Table 2 SFS volume configuration parameters
    name
    storage
    File storage size in the unit of Gi. Use the value of spec.capacity.storage of the FlexVolume PV.
    driver
    Storage driver used to attach the volume. Set the driver to nas.csi.everest.io for the file system.
    Shared path of the file system. Use the value of spec.flexVolume.options.deviceMountPath of the FlexVolume PV.
    volumeHandle
    File system ID. Use the value of spec.flexVolume.options.volumeID of the FlexVolume PV.
    storageClassName
    Name of the Kubernetes storage class. Set this field to csi-nas.
    Configuration example of a PV for an OBS volume:
    apiVersion: v1
      annotations:
      accessModes:
      - ReadWriteMany
      capacity:
        storage: 1Gi
      csi:
        driver: obs.csi.everest.io
        fsType: s3fs
        volumeAttributes:
          everest.io/obs-volume-type: STANDARD
          everest.io/region: eu-west-0
        volumeHandle: obs-normal-static-pv
      storageClassName: csi-obs
    Table 3 OBS volume configuration parameters
    name
    storage
    Storage capacity, in the unit of Gi. Set this parameter to the fixed value 1Gi.
    driver
    Storage driver used to attach the volume. Set the driver to obs.csi.everest.io for the OBS volume.
    fsType
    File type. Value options are obsfs or s3fs. If the value is s3fs, an OBS bucket is created and mounted using s3fs. If the value is obsfs, an OBS parallel file system is created and mounted using obsfs. Set this parameter according to the value of spec.flexVolume.options.posix of the FlexVolume PV. If the value of spec.flexVolume.options.posix is true, set this parameter to obsfs. If the value is false, set this parameter to s3fs.
    Storage class, including STANDARD (standard bucket) and WARM (infrequent access bucket). Set this parameter according to the value of spec.flexVolume.options.storage_class of the FlexVolume PV. If the value of spec.flexVolume.options.storage_class is standard, set this parameter to STANDARD. If the value is standard_ia, set this parameter to WARM.
    everest.io/region
    Region where the OBS bucket is located. Use the value of spec.flexVolume.options.region of the FlexVolume PV.
    volumeHandle
    OBS bucket name. Use the value of spec.flexVolume.options.volumeID of the FlexVolume PV.
    storageClassName
    Name of the Kubernetes storage class. Set this field to csi-obs.
    Configuration example of a PV for an SFS Turbo volume:
    apiVersion: v1
      annotations:
      accessModes:
      - ReadWriteMany
      capacity:
        storage: 10Gi
      csi:
        driver: sfsturbo.csi.everest.io
        fsType: nfs
        volumeAttributes:
          everest.io/share-export-location: 192.168.0.169:/
        volumeHandle: 8962a2a2-a583-4b7f-bb74-fe76712d8414
      storageClassName: csi-sfsturbo
    Table 4 SFS Turbo volume configuration parameters
    name
    storage
    File system size. Use the value of spec.capacity.storage of the FlexVolume PV.
    driver
    Storage driver used to attach the volume. Set it to sfsturbo.csi.everest.io.
    Shared path of the SFS Turbo volume. Use the value of spec.flexVolume.options.deviceMountPath of the FlexVolume PV.
    volumeHandle
    SFS Turbo volume ID. Use the value of spec.flexVolume.options.volumeID of the FlexVolume PV.
    storageClassName
    Name of the Kubernetes storage class. Set this field to csi-sfsturbo for SFS Turbo volumes.
  3. Configure a YAML file of the PVC in the CSI format according to the PVC in the FlexVolume format and associate the PVC with the PV created in 2.
    To be specific, run the following commands to configure the pvc-example.yaml file, which is used to create a PVC.
    touch pvc-example.yaml
    vi pvc-example.yaml
    Configuration example of a PVC for an EVS volume:
    apiVersion: v1
    kind: PersistentVolumeClaim
      labels:
      annotations:
        volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
      namespace: default
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      volumeName:  pv-evs-example
    Table 5 PVC configuration parameters for an EVS volume
    Region where the cluster is located. Use the same value as that of the FlexVolume PVC.
    AZ where the EVS disk is deployed. Use the same value as that of the FlexVolume PVC.
    Storage class of the EVS disk. The value can be SAS or SSD. Set this parameter to the same value as that of the PV created in 2.
    name
    PVC name, which must be unique in the namespace. The value must be unique in the namespace. (If the PVC is dynamically created by a stateful application, the value of this parameter must be the same as the name of the FlexVolume PVC.)
    namespace
    Namespace to which the PVC belongs. Use the same value as that of the FlexVolume PVC.
    storage
    Requested capacity of the PVC, which must be the same as the storage size of the existing PV.
    volumeName
    Name of the PV. Set this parameter to the name of the static PV in 2.
    storageClassName
    Name of the Kubernetes storage class. Set this field to csi-disk for EVS disks.
    Configuration example of a PVC for an SFS volume:
    apiVersion: v1
      annotations:
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 10Gi
      volumeName: pv-sfs-example
    Table 6 PVC configuration parameters for an SFS volume
    name
    namespace
    storage
    Storage capacity, in the unit of Gi. The value must be the same as the storage size of the existing PV.
    storageClassName
    volumeName
    Configuration example of a PVC for an OBS volume:
    apiVersion: v1
      annotations:
        csi.storage.k8s.io/fstype: s3fs
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi
      volumeName: pv-obs-example
    Table 7 PVC configuration parameters for an OBS volume
    OBS volume type, which can be STANDARD (standard bucket) and WARM (infrequent access bucket). Set this parameter to the same value as that of the PV created in 2.
    File type, which can be obsfs or s3fs. The value must be the same as that of fsType of the static OBS volume PV.
    name
    namespace
    storage
    storageClassName
    volumeName
    Name of the PV. Set this parameter to the name of the static PV created in 2.
    Configuration example of a PVC for an SFS Turbo volume:
    apiVersion: v1
      annotations:
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 10Gi
      volumeName: pv-efs-example
    Table 8 PVC configuration parameters for an SFS Turbo volume
    name
    namespace
    storageClassName
    Name of the Kubernetes storage class. Set this field to csi-sfsturbo.
    storage
    volumeName
  4. Upgrade the workload to use a new PVC.
    For Deployments
    1. Run the kubectl create -f commands to create a PV and PVC.
      kubectl create -f pv-example.yaml
      kubectl create -f pvc-example.yaml
      Replace the example file name pvc-example.yaml in the preceding commands with the names of the YAML files configured in 2 and 3.
    2. Go to the CCE console. On the workload upgrade page, click Upgrade > Advanced Settings > Data Storage > Cloud Storage.
    3. Uninstall the old storage and add the PVC in the CSI format. Retain the original mounting path in the container.
    4. Click Submit.
    5. Wait until the pods are running.
    For StatefulSets that use existing storage
    2. Run the kubectl edit command to edit the StatefulSet and use the newly created PVC.
      kubectl edit sts sts-example -n xxx
      Replace sts-example in the preceding command with the actual name of the StatefulSet to upgrade. xxx indicates the namespace to which the StatefulSet belongs.
    3. Wait until the pods are running.
    The current console does not support the operation of adding new cloud storage for StatefulSets. Use the kubectl commands to replace the storage with the newly created PVC.
    For StatefulSets that use dynamically allocated storage
    1. Back up the PV and PVC in the flexVolume format used by the StatefulSet.
      kubectl get pvc xxx -n {namespaces} -oyaml > pvc-backup.yaml
      kubectl get pv xxx -n {namespaces} -oyaml > pv-backup.yaml
    2. Change the number of pods to 0.
    3. On the storage page, disassociate the flexVolume PVC used by the StatefulSet.
    4. Run the kubectl create -f commands to create a PV and PVC.
    5. Change the number of pods back to the original value and wait until the pods are running.
    The dynamic allocation of storage for StatefulSets is achieved by using volumeClaimTemplates. This field cannot be modified by Kubernetes. Therefore, data cannot be migrated by using a new PVC.
    The PVC naming rule of the volumeClaimTemplates is fixed. When a PVC that meets the naming rule exists, this PVC is used.
    Therefore, disassociate the original PVC first, and then create a PVC with the same name in the CSI format.
    6. (Optional) Recreate the stateful application to ensure that a CSI PVC is used when the application is scaled out. Otherwise, FlexVolume PVCs are used in scaling out.
    • Run the following command to obtain the YAML file of the StatefulSet:
    kubectl get sts xxx -n {namespaces} -oyaml > sts.yaml
    • Run the following command to back up the YAML file of the StatefulSet:
    cp sts.yaml sts-backup.yaml
    • Modify the definition of volumeClaimTemplates in the YAML file of the StatefulSet.
    vi sts.yaml
    Configuration example of volumeClaimTemplates for an EVS volume:
      volumeClaimTemplates:
        - metadata:
            namespace: default
            creationTimestamp: null
            annotations:
            accessModes:
              - ReadWriteOnce
            resources:
              requests:
                storage: 10Gi
    The parameter value must be the same as the PVC of the EVS volume created in 3.
    Configuration example of volumeClaimTemplates for an SFS volume:
        - metadata:
            namespace: default
            accessModes:
              - ReadWriteMany
            resources:
              requests:
                storage: 10Gi
    The parameter value must be the same as the PVC of the SFS volume created in 3.
    Configuration example of volumeClaimTemplates for an OBS volume:
        - metadata:
            namespace: default
            annotations:
            accessModes:
              - ReadWriteMany
            resources:
              requests:
                storage: 1Gi
    The parameter value must be the same as the PVC of the OBS volume created in 3.
    • Delete the StatefulSet.
    kubectl delete sts xxx -n {namespaces}
    • Create the StatefulSet.
    kubectl create -f sts.yaml
  5. Check service functions.
    1. Check whether the application is running properly.
    2. Checking whether the data storage is normal.
    If a rollback is required, perform 4. Select the PVC in FlexVolume format and upgrade the application.
  6. Uninstall the PVC in the FlexVolume format.
    If the application functions normally, unbind the PVC in the FlexVolume format on the storage management page.
    You can also run the kubectl command to delete the PVC and PV of the FlexVolume format.
    Before deleting a PV, change the persistentVolumeReclaimPolicy of the PV to Retain. Otherwise, the underlying storage will be reclaimed after the PV is deleted.
    If the cluster has been upgraded before the storage migration, PVs may fail to be deleted. You can remove the PV protection field finalizers to delete PVs.
    kubectl patch pv {pv_name} -p '{"metadata":{"finalizers":null}}'
