Kubernetes
Typical native configuration items are provided. You can configure native community management components such as kube-apiserver and kube-controller for the best cloud native experience.
API Server Configuration (kube-apiserver)
Container eviction configuration
By default, the default tolerance time applies to all containers in a cluster. You can also configure different tolerance times for pods. In this case, your custom settings take effect.
It is recommended that you properly configure the tolerance times for pods, or certain problems may occur.
- If the parameter is set to a low value, containers may be moved frequently during brief fault scenarios like network jitter, which can impact services.
- If the parameter is set to a high value, containers may not be moved for a long period of time in the event of a node failure, which can impact services.
Item |
Parameter |
Description |
Value |
Toleration time for nodes in NotReady state |
default-not-ready-toleration-seconds |
Tolerance time when a node is not ready. If a node becomes unavailable, pods running on the node are evicted automatically after the tolerance time elapses. The default value is 300s. |
Default: 300s |
Toleration time for nodes in unreachable state |
default-unreachable-toleration-seconds |
Tolerance time when a node is unreachable. If the environment is abnormal, for example, a node cannot be accessed (due to reasons such as abnormal node network), pods running on the node are evicted automatically after the tolerance time elapses. The default value is 300s. |
Default: 300s |
Admission Controller Add-on Configurations
With Kubernetes, you can enable admission add-ons to limit and manage Kubernetes API objects (like pods, Services, and Deployments) prior to modifying them within a cluster.
This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
Item |
Parameter |
Description |
Value |
Node Restriction Add-on |
enable-admission-plugin-node-restriction |
This add-on allows the kubelet of a node to operate only the objects of the current node for enhanced isolation in multi-tenant scenarios or the scenarios with high security requirements. For details, see the official documentation. |
Enable/Disable |
Pod Node Selector Add-on |
enable-admission-plugin-pod-node-selector |
This add-on allows cluster administrators to configure the default node selector through namespace annotations. In this way, pods run only on specific nodes and configurations are simplified. |
Enable/Disable |
Pod Toleration Limit Add-on |
enable-admission-plugin-pod-toleration-restriction |
This add-on allows cluster administrators to configure the default value and limits of pod tolerations through namespaces for fine-grained control over pod scheduling and key resource protection. |
Enable/Disable |
Service Account Token Volume Projection
This parameter is available only in clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions.
Item |
Parameter |
Description |
Value |
API Audience Settings |
api-audiences |
Audiences for a service account token. The Kubernetes component for authenticating service account tokens checks whether the token used in an API request specifies authorized audiences. Configuration suggestion: Accurately configure audiences according to the communication needs among cluster services. By doing so, the service account token is used for authentication only between authorized services, which enhances security.
An incorrect configuration may lead to an authentication communication failure between services or an error during token verification. |
Default value: "https://kubernetes.default.svc.cluster.local" Multiple values can be configured, which are separated by commas (,). |
Service Account Token Issuer Identity |
service-account-issuer |
Entity identifier for issuing a service account token, which is the value identified by the iss field in the payload of the service account token. Configuration suggestion: Ensure the configured issuer URL can be accessed in the cluster and trusted by the authentication system in the cluster.
If your specified issuer URL is untrusted or inaccessible, the authentication process based on the service account may fail. |
Controller Configuration (kube-controller-manager)
Common Configurations of the Controller
- Controller performance configuration: used to configure performance parameters for the controller to access kube-apiserver.
It is recommended that you properly configure the controller performance settings, or certain problems may occur.
- If a parameter is set to a small value, client traffic limiting may be triggered, affecting controller performance.
- If a parameter is set to a large value, kube-apiserver may be overloaded.
Table 4 Parameters Item
Value
QPS for communicating with kube-apiserver
kube-api-qps
QPS for communication with kube-apiserver
- If the number of nodes in a cluster is less than 1,000, the default value is 100.
- If the number of nodes in a cluster is 1,000 or more, the default value is 200.
Burst for communicating with kube-apiserver
kube-api-burst
Burst for communication with kube-apiserver
- Cluster controller concurrent configuration: specifies the number of resource objects that are allowed to synchronize simultaneously. A larger value indicates a quicker response and higher CPU (and network) load.
It is recommended that you properly configure the controller concurrency, or certain problems may occur.
- If a parameter is set to a small value, the controller may respond slowly.
- If a parameter is set to a large value, the cluster management plane will be overloaded.
Table 5 Parameters Item
Value
Number of concurrent processing of deployment
concurrent-deployment-syncs
Number of deployment objects that can be synchronized concurrently. A larger value indicates a quicker response to Deployments and higher CPU (and network bandwidth) pressure.
Default: 5
Concurrent processing number of endpoint
concurrent-endpoint-syncs
Number of endpoints that can be concurrently synchronized. A larger value indicates faster update of endpoints and higher CPU (and network) pressure.
Default: 5
Concurrent number of garbage collectors
concurrent-gc-syncs
Number of garbage collector workers that are allowed to synchronize concurrently.
Default: 20
Number of job objects allowed to sync simultaneously
concurrent-job-syncs
Number of job objects that can be synchronized concurrently. A larger value indicates a quicker response to jobs and higher CPU (and network) usage.
Default: 5
Number of CronJob objects allowed to sync simultaneously
concurrent-cron-job-syncs
Number of CronJob objects that can be synchronized concurrently. A larger value indicates a quicker response to CronJobs and higher CPU (and network) usage.
Default: 5
Number of concurrent processing of namespace
concurrent-namespace-syncs
Number of namespace objects that can be synchronized concurrently. A larger value indicates a quicker response to namespaces and higher CPU (and network) usage.
Default: 10
Concurrent processing number of replicaset
concurrent-replicaset-syncs
Number of ReplicaSet objects that can be synchronized concurrently. A larger value indicates a quicker response to ReplicaSet management and higher CPU (and network) usage.
Default: 5
Number of concurrent processing of resource quota
concurrent-resource-quota-syncs
Number of ResourceQuota objects that can be synchronized concurrently. A larger value indicates a faster response to quota management and higher CPU (and network) usage.
Default: 5
Servicepace
concurrent-service-syncs
Number of Service objects that can be synchronized concurrently. A larger value indicates a faster response to Service management and higher CPU (and network) usage.
Default: 10
Concurrent processing number of serviceaccount-token
concurrent-serviceaccount-token-syncs
Number of service account token objects that can be synchronized concurrently. A larger value indicates faster token generation and higher CPU (and network) usage.
Default: 5
Concurrent processing of ttl-after-finished
concurrent-ttl-after-finished-syncs
Number of ttl-after-finished-controller workers that can be synchronized concurrently.
Default: 5
RC
concurrent_rc_syncs
Number of replication controllers that can be synchronized concurrently. A larger value indicates faster replica management operations and higher CPU (and network) usage.
NOTE:This parameter is used only in clusters of v1.19 or earlier.
Default: 5
RC
concurrent-rc-syncs
NOTE:This parameter is used only in clusters of v1.21 to v1.23. In clusters of v1.25 and later, this parameter is deprecated (officially deprecated from v1.25.3-r0 on).
Default: 5
HPA
concurrent-horizontal-pod-autoscaler-syncs
Maximum number of HPA auto scaling requests that can be processed concurrently. A larger value indicates a faster HPA auto scaling and higher CPU (and network) usage.
This parameter is available only in clusters of v1.27 or later.
Default: 5
Value range: 1 to 50
Node lifecycle controller (node-lifecycle-controller) configuration
Item |
Parameter |
Description |
Value |
Unhealthy AZ Threshold |
unhealthy-zone-threshold |
When more than a certain proportion of pods in an AZ are unhealthy, the AZ itself will be considered unhealthy, and scheduling pods to nodes in that AZ will be restricted to limit the impacts of the unhealthy AZ.
If the parameter is set to a large value, pods in unhealthy AZs will be migrated in a large scale, which may lead to risks such as overloaded clusters. |
Default: 0.55 |
Node Eviction Rate |
node-eviction-rate |
This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is healthy. The default value is 0.1, indicating that pods can be evicted from at most one node every 10 seconds.
Configure this parameter based on the size of the cluster. The number of pods to be evicted in each batch should not exceed 300. If the parameter is set to a large value, the cluster may be overloaded. Additionally, if too many pods are evicted, they cannot be rescheduled, which will slow down fault recovery. |
Default: 0.1 |
Secondary Node Eviction Rate |
secondary-node-eviction-rate |
This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is unhealthy. The default value is 0.01, indicating that pods can be evicted from at most one node every 100 seconds.
Configure this parameter with node-eviction-rate and set it to one-tenth of node-eviction-rate. There is no need to set the parameter to a large value for nodes in an unhealthy AZ, and this configuration may result in overloaded clusters. |
Default: 0.01 |
Large Cluster Threshold |
large-cluster-size-threshold |
If the number of nodes in a cluster is greater than the value of this parameter, this is a large cluster. Configuration suggestion: For the clusters with a large number of nodes, configure a relatively larger value than the default one for higher performance and faster responses of controllers. Retain the default value for small clusters. Before adjusting the value of this parameter in a production environment, check the impact of the change on cluster performance in a test environment.
kube-controller-manager automatically adjusts configurations for large clusters to optimize the cluster performance. Therefore, an excessively small threshold for small clusters will deteriorate the cluster performance. |
Default: 50 |
Load elastic scaling synchronization cycle
Item |
Parameter |
Description |
Value |
Cluster elastic computing period |
horizontal-pod-autoscaler-sync-period |
Period for the horizontal pod autoscaler to perform elastic scaling on pods. A smaller value will result in a faster auto scaling response and higher CPU load.
Make sure to configure this parameter properly as a lengthy period can cause the controller to respond slowly, while a short period may overload the cluster management plane. |
Default: 15s |
Horizontal Pod Scaling Tolerance |
horizontal-pod-autoscaler-tolerance |
The configuration determines how quickly HPA will act to auto scaling policies. If the parameter is set to 0, auto scaling will be triggered immediately when the related metrics are met. Configuration suggestion: If the service resource usage increases sharply over time, retain a certain tolerance to prevent auto scaling which is beyond expectation in high resource usage scenarios. |
Default: 0.1 |
HPA CPU Initialization Period |
horizontal-pod-autoscaler-cpu-initialization-period |
During the period specified by this parameter, the CPU usage data used in HPA calculation is limited to pods that are both ready and have recently had their metrics collected. You can use this parameter to filter out unstable CPU usage data during the early stage of pod startup. This helps prevent incorrect scaling decisions based on momentary peak values. Configuration suggestion: If you find that HPA is making incorrect scaling decisions due to CPU usage fluctuations during pod startup, increase the value of this parameter to allow for a buffer period of stable CPU usage.
Make sure to configure this parameter properly as a small value may trigger unnecessary scaling based on peak CPU usage, while a large value may cause scaling to be delayed. This parameter is available only in clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions. |
Default: 5 minutes |
HPA Initial Readiness Delay |
horizontal-pod-autoscaler-initial-readiness-delay |
After CPU initialization, this period allows HPA to use a less strict criterion for getting CPU metrics. During this period, HPA will gather data on the CPU usage of the pod for scaling, regardless of any changes in the pod's readiness status. This parameter ensures continuous tracking of CPU usage, even when the pod status changes frequently. Configuration suggestion: If the readiness status of pods fluctuates after startup and you want to prevent HPA misjudgment caused by the fluctuation, increase the value of this parameter to allow HPA to gather more comprehensive CPU usage data.
Configure this parameter properly. If it is set to a small value, an unnecessary scale-out may occur due to CPU data fluctuations when the pod is just ready. If it is set to a large value, HPA may not be able to make a quick decision when a rapid response is needed. This parameter is available only in clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions. |
Default: 30s |
Threshold configuration of the number of terminal state pods that trigger recycling
Item |
Parameter |
Description |
Value |
The maximum number of terminated pods that can be kept before the Pod GC deletes the terminated pod |
terminated-pod-gc-threshold |
Number of terminated pods that can exist before the terminated pod garbage collector starts deleting terminated pods
It is recommended that you properly configure this parameter. If the value is too large, there may be a large number of terminated pods in the cluster, which will further affect the performance of list queries and result in an overloaded cluster. |
Default: 1000 Value range: 10 to 12500 |
Resource quota controller (resource-quota-controller) configuration
In high-concurrency scenarios (for example, creating pods in batches), the resource quota management may cause some requests to fail due to conflicts. Do not enable this function unless necessary. To enable this function, ensure that there is a retry mechanism in the request client.
Item |
Parameter |
Description |
Value |
Enable resource quota management |
enable-resource-quota |
With resource quota management, you are allowed to control the number of workloads (such as Deployments and pods) and the upper limits of resources (such as CPUs and memory) in namespaces or related dimensions. Namespaces control quotas through the ResourceQuota objects.
Default: false |
