Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Network/ Ingresses/ Nginx Ingresses/ Configuring HTTPS Backend Services for an Nginx Ingress
Ingress can function as a proxy for backend services using different protocols. By default, the backend proxy channel of an ingress is an HTTP channel. To create an HTTPS channel, add the following configuration to the annotations field:
nginx.ingress.kubernetes.io/backend-protocol: "HTTPS"
An ingress configuration example is as follows:
For clusters of v1.23 or later:
kind: Ingress
  namespace: default
  annotations:
  tls:
    - secretName: ingress-test-secret  # Replace it with your TLS key certificate.
  rules:
    - host: ''
      http:
        paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: <your_service_port>  # Replace it with the port number of your target Service.
            property:
  ingressClassName: nginx
For clusters of v1.21 or earlier:
apiVersion: networking.k8s.io/v1beta1
kind: Ingress
  namespace: default
  annotations:
    kubernetes.io/ingress.class: nginx
  tls:
  rules:
    - host: ''
      http:
        paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: <your_service_port>  # Replace it with the port number of your target Service.
