Updated on 2024-01-26 GMT+08:00
Node and Container Network Check
Check Item
  • Check whether the nodes are running properly.
  • Check whether the node network is normal.
  • Check whether the container network is normal.
The node status reflects whether the node component or network is normal.
Go to the CCE console and access the cluster console. Choose Nodes in the navigation pane. You can filter node status by status to check whether there are abnormal nodes.
The container network affects services. Check whether your services are available.
Solution
If the node status is abnormal, contact technical support.
If the container network is abnormal and your services are affected, contact technical support and confirm the abnormal network access path.
Source
Destination
Destination Type
Possible Fault
  • Pods (inside a cluster)
  • Nodes (inside a cluster)
  • Cloud servers outside the cluster but in the same VPC as the cluster
  • Outside the VPC to which the cluster belongs
Public IP address of Service ELB
Cluster traffic load balancing entry
No record.
Private IP address of Service ELB
No record.
Public IP address of ingress ELB
No record.
Private IP address of ingress ELB
No record.
Public IP address of NodePort Service
Cluster traffic entry
The kube proxy configuration is overwritten. This fault has been rectified in the upgrade process.
Private IP address of NodePort Service
No record.
ClusterIP Service
Service network plane
No record.
Non NodePort Service port
Container network
No record.
Cross-node pods
Container network plane
No record.
Pods on the same node
No record.
Service and pod domain names are resolved by CoreDNS.
Domain name resolution
No record.
External domain names are resolved based on the CoreDNS hosts configuration.
After CoreDNS is upgraded, the configuration is overwritten. This fault has been rectified in the add-on upgrade process.
External domain names are resolved based on the CoreDNS upstream server.
External domain names are not resolved by CoreDNS.
No record.
