Key Node Commands
Check Items
Whether some key commands that the node upgrade depends on are working
Solution
  • Scenario 1: Executing the package manager command failed.
    Executing the rpm or dpkg command failed. In this case, log in to the affected node and check whether the following commands are available:
    • rpm:
      rpm -qa
      Run the following command for recovery:
      rpm --rebuilddb
    • dpkg:
      dpkg -l
      dpkg --configure -a
  • Scenario 2: The systemctl status command fails to be executed.
    If the systemctl status command on a node is unavailable, many check items will be affected. Log in to the node and check the availability of the following commands:
    systemctl status kubelet
  • Scenario 3: Executing the Python command failed.
    Check whether the command can be executed on the node.
    /usr/bin/python --version
If the fault persists, reset the node. For details, see Resetting a Node.
