Stopping a Node
When a node in the cluster is stopped, all services on that node will also be stopped, and the node will no longer be available for scheduling. Check if your services will be affected before stopping a node.
Precautions
  • Deleting a node will lead to pod migration, which may affect services. Perform this operation during off-peak hours.
  • Unexpected risks may occur during the operation. Back up data beforehand.
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
  3. Locate the target node and click its name.
  4. In the upper right corner of the ECS details page, click Stop. In the displayed dialog box, click Yes.
