Adding a Gateway Response
A gateway response is displayed if API Gateway fails to process an API request. API Gateway provides a set of default responses and also allows you to create gateway responses with custom status codes and content, on the API Groups page. The response content must be in JSON format.
For example, the content of a default gateway response is as follows:
{"error_code": "$context.error.code", "error_msg": "$context.error.message", "request_id": "$context.requestId"}
You can add a response with the following content:
{"errorcode": "$context.error.code", "errormsg": "$context.error.message", "requestid": "$context.requestId","apiId":"$context.apiId"}
You can add more fields to or delete existing fields from the JSON body.
- The default gateway responses provided by API Gateway can be edited.
- You can create gateway responses and configure different responses for APIs in the same API group.
- The type of a gateway response cannot be changed. For details, see Response Types.
- Gateway responses can contain the API gateway context variables (starting with $context). For details, see API Gateway Context Variables.
You have created an API group.
- Click
in the upper left corner and choose API Gateway. - In the navigation pane, choose API Publishing > API Groups.
- Locate the API group for which you want to create or modify a gateway response, and click the group name to go to the API group details page.
- Click the Gateway Responses tab and create a gateway response.
- To edit a response, click the Edit button in the upper right corner and modify the status code and content of the response.
- You can modify only the status code and content of a default or custom gateway response, and you cannot change the response type.
- Error information and other response details can be obtained using variables. For details about the supported variables, see Table 2.
Response Types
Table 1 lists the response types supported by API Gateway. You can define status codes of responses to meet your service requirements.
Response Name |
Default Status Code |
Description |
Access Denied |
403 |
Access denied. For example, the access control policy is triggered or an attack is detected. |
Authorizer Configuration Error |
500 |
A custom authorizer error has occurred. For example, communication failed or an error response was returned. |
Authorizer Failed |
500 |
The custom authorization failed. |
Incorrect Identity Source |
401 |
The identity source of the custom authorizer is missing or invalid. |
Authentication Failure |
401 |
IAM or app authentication failed. |
Identity Source Not Found |
401 |
No identity source has been specified. |
Backend Timeout |
504 |
Communication with the backend service timed out. |
Backend Unavailable |
502 |
The backend service is unavailable due to communication error. |
Default 4XX |
Another 4XX error occurred. |
Default 5XX |
Another 5XX error occurred. |
No API Found |
No API is found. |
Incorrect Request Parameters |
404 |
The request parameters are incorrect or the HTTP method is not supported. |
Request Throttled |
429 |
The request was rejected due to request throttling. |
Unauthorized App |
401 |
The app you are using has not been authorized to call the API. |
Variable |
Description |
$context.apiId |
API ID. |
$context.appId |
ID of the app that calls the API. |
$context.requestId |
Tracing ID generated when the API is called. |
$context.stage |
Deployment environment in which the API is called. |
$context.sourceIp |
Source IP address of the API caller. |
$context.authorizer.frontend.property |
Values of the specified attribute–value pairs mapped to the context in the frontend custom authorizer response |
$context.authorizer.backend.property |
Values of the specified attribute–value pairs mapped to the context in the backend custom authorizer response |
$context.error.message |
Error message. |
$context.error.code |
Error code. |
$context.error.type |
Error type. |
