Priority
This parameter specifies the rule priority. If you have added multiple rules, rules are matched by priority. The smaller the value you set, the higher the priority.
You can use the priority function to rank all precise protection rules to get the optimal protection.
If multiple precise access control rules have the same priority, WAF matches the rules in the sequence of time the rules are added.
