Load Balancer Type
It specifies the type of the load balancer interconnected with an ingress. Shared and dedicated load balancers are supported, and they can be created automatically.
Select a proper load balancer type.
Value Range
- union: shared load balancers
- performance: (Recommended) dedicated load balancers. They are supported by clusters 1.17 or later.
Default Value
performance
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Set the parameter to performance. Dedicated load balancers support advanced features like source address persistence and passthrough networking.
Shared load balancers do not support source address persistence. In CCE Turbo clusters, shared load balancers do not support passthrough networking and can only be used in the NodePort Services.
